Well, I know my supply has 5.1V on the +5 and 11.8V on the +12. If you don't have any type of load to spare, then you'll have to use resistors. For the +12 use a 10 watt 18 ohm (or so) resistor. A 10 watt automotive bulb would work here too. For the +5 use a 10 watt 3 ohm (or so) resistor. These should load the supply enough to get a stable voltage out.Originally posted by marsjell:
<STRONG>arby or presslab,
could one of you do me a favour and measure the voltage on the +12V & +5V output? mine are +26V and +8V, presslab said too try and connect an old HD or something and measure again, but I'm scared I'll blow up the hd, I don't have anything old that I can attach..
thanx,
Marsjell</STRONG>
Presslab
LinkBack URL
About LinkBacks
this vacation is almost over u know.
