Results 1 to 4 of 4
Thread: dc - ac power inverter
    Philly
    Hey all,
    what's the best DC - AC power inverter and where can I buy it?
    I've heard that some DC -AC inverters will cause noise and flicker. My other question would be if I get an inverter with noise would I be able to connect an ITPS regulator to regulate the voltage? I'm understanding that the reving or the change in voltage cause noise... Not sure if I'm correct.
    and yes I did ...
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    rebuilding carpc... kinda..
    Philly
    ok that answers the inverter part....but puting an ITPS regulator before the battery do anything?
    Battery + ITPS regulator + DC-AC power inverter
    Nov 2003
    CT
    "Input voltage range 10-15 VDC"
    cranking brings the car down to 7-10 volts, normally, so if you want to be able to survive crank, and your ITPS can handle it, sure.
    or you can search for tank circuits here to keep the voltage up during crank
  1. WTB: 60 Watt, 12 Volt AC to DC Power Brick
    By chut in forum Classified Archive
    Last Post: 11-16-2005, 03:19 PM
  2. Rookie Guide to CarPC's
    By IntellaWorks in forum Newbie
    Last Post: 09-21-2005, 04:43 PM
  3. HELP on Using Inverter and UPS to power carpc
    By davidbudi in forum Power Supplies
    Last Post: 04-27-2005, 11:36 AM
  4. cut AC transformer off USB Hub power to connect DC?
    By ITL in forum Hardware Development
    Last Post: 04-23-2005, 04:19 PM
  5. DC power to AC ?
    By berdine3 in forum General Hardware Discussion
    Last Post: 10-23-2004, 11:48 AM
