Results 1 to 10 of 14
Thread: Opus compatible with micro-atx mobos
    Constant Bitrate ironic's Avatar
    Aug 2005
    Gibraltar(UK)
    Question Opus compatible with micro-atx mobos
    Guys can i use the Opus dc-dc 150w to power a micro-atx mobo?
    Thanks!
    Elsewhere
    The Opus is an ATX-spec power supply. What do you think?
    How about the Wiki?
    Aug 2005
    Gibraltar(UK)
    well, i really dont know!thats why i ask.i would suppose it would be able to use it no problems.Please confirm this for me?
    i have found a small micro-atx mobo and thanks to this i think i mite go for it, but i knew that i cudnt use a normal psu on a micro atx mobo, or so i have read.is this true?
    thanks DP
    Elsewhere
    The key word (or acronym in this case) is ATX.
    How about the Wiki?
    Aug 2005
    Gibraltar(UK)
    sorry dude but i still dont understand wot ur saying.
    all i need is: "yes u can use a atx psu on a micro-atx mobo" or not.
    "yes you can use the opus 150w with a micro-atx mobo" or not.
    thanks and sorry!
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    In most cases you can without problems. Micro-ATX boards use ATX power supplies, and as such the Opus will power all these motherboards. However, the auto-'power-on' feature of the Opus can sometimes have problems turning on specific motherboards. I had a problem with a Biostar, the Opus just wouldn't turn it on....timing issue I think.
    Anyhow, fire off an Email to Opus Technologies with the make/model of the motherboard & they will tell you if its compatible of if they can sell you a 'tweaked' version that they have made so. They have been known to make modifications the the start up electronics for problem motherboards.
    Elsewhere
    Quote Originally Posted by ironic
    thanks and sorry!
    I'm trying to get you to think for yourself. You're going to need to do that quite a bit if you're planning on putting a computer in your vehicle.
    How about the Wiki?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i dont understand why some people decided to build a computer in a car.....before they've ever built a computer
    PC Components:
    My work log
    Newbie gqmd's Avatar
    Jul 2001
    Maryland
    With most motherboards it will be compatible. There are a few however that will require a slight modification that you will need. Just tell your supplier prior to purchasing. This modification is done free of charge. The motherboards affected are the following:
    · Compatibility issues
    Please consult with us before purchasing our 150W power supply for the folowing motherboards: Biostar M7NCG, Via Epia CL series, Via Epia PD series
    I have the Biostar (which did require the slight modification) and have had great success with my setup.
    Hope it helped. Just ignore the idiots who would not answer your questions and gave sarcastic remarks. They lack manners and a decent college education.
    Good luck with your setup
    Biostar MicroATX with 2600+ XP-M
    Xenarc TS VGA
    60GB Notebook Drive
    Opus 150W PSU
    Rikaline 6010 GPS
    Gyration Keyboard and Mouse (for passengers)
    Creative USB Sound Processor for easy headunit aux input integration
    Motorola Droid Wifi Hotspot service
    Aug 2005
    Gibraltar(UK)
    thank you all for ur help guys!!
    now i understand a bit more, and btw, i have built numerous pc's myself. the only thing is i have never delt with micro-atx mobos before, and heard erroneous comments! just trying to get things straight here.
    again thank u all!
  1. Micro ATX or ATX
    By custardbomb in forum Power Supplies
    Last Post: 08-14-2005, 07:48 AM
  2. Opus atx power (on off) like this?
    By Mad Ad in forum Hardware Development
    Last Post: 05-08-2005, 08:11 PM
  3. OPUS 150 do I really Need the 4 pin atx cable
    By cl6four3 in forum Power Supplies
    Last Post: 05-08-2005, 08:08 PM
  4. Replies: 3
    Last Post: 05-06-2005, 11:29 PM
  5. micro / mini atx system w/ LCD and all the goodies
    By gizmomkr in forum Classified Archive
    Last Post: 05-09-2001, 04:08 PM
