Results 1 to 10 of 14
Thread: 2 LM7805's in Parallel
    Dec 2004
    Is it possible to hook two LM7805 regulators up in parallel to give a +5V 2A supply (as opposed to a +5V 1A supply)?
    Maximum Bitrate DJiK's Avatar
    Apr 2005
    Los Angeles (Winnetka), CA
    Looks like they've done something similar here.
    For Sale: Carputer (CarPC) & RCA Y-Adapter
    Newsflash: Take a look at my unsold stuff above, thanks!
    Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
    Low Bitrate agentloveless's Avatar
    Aug 2005
    So Cal
    Yes, hooked up in parallel they should give 2A. Be sure they sit far enough apart that both are allowed to disipate there heat.
    Dec 2004
    Quote Originally Posted by DJiK
    It looks like that is two separate regulators with two separate outputs.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    it won't work very well, most the time one of the regulators will try to take all the load and shutdown. Your much better off going with a switching regulator for a load that high. The carnetix POL works really really well in this situation and gives you 3A
    肚子笑痛了
    S60 Install
    Dec 2004
    Quote Originally Posted by jcdillin
    Yeah thats what I figured. I just wanted a cheap alternative to the carnetix POL; since the LM's are only <$2.00 each.
    Variable Bitrate Fox_Mulder's Avatar
    Melbourne, Australia The Truth Is Out There
    You can use a TIP2955 Transistor to increase the current output.
    Eg: http://www.mitedu.freeserve.co.uk/Ci...er/1230psu.htm
    Fox Mulder
    2001 Toyota Avalon Vxi
    Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
    2004 Toyota MR2
    Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Or just use a LM123 regulator. It's 5v 3amp regulator.
    Dec 2004
    Quote Originally Posted by shotgunefx
    Nice, the LM123 is essentially what I'm looking for. Do you know any cheap places to buy them?
    Apr 2005
    Boston, MA
    Quote Originally Posted by bruha
    I got mine at mouser, not sure what I payed for em.
  1. Electronics Question - Parallel Relay
    By blazinlow in forum General Hardware Discussion
    Last Post: 11-07-2004, 01:39 PM
  2. parallel port LCD problem
    By jethari in forum LCD/Display
    Last Post: 09-05-2004, 10:56 PM
  3. need a extra serial or parallel port?
    By Sway in forum Input Devices
    Last Post: 01-08-2004, 07:48 AM
  4. Crystal Fontz parallel LCD
    By CaffeineAddict in forum LCD/Display
    Last Post: 09-27-2001, 02:55 PM
  5. I need another parallel port
    By jasmar in forum General Hardware Discussion
    Last Post: 08-03-2000, 11:13 AM
