Results 1 to 8 of 8
Thread: Too much power consumption with 300w - Need help
    Oct 2001
    Anniston, AL
    Post Too much power consumption with 300w - Need help
    I'm having a huge power problem with my carmp3 system.( BOOKPC, 500mhz, 40gb, 256mb ram, 5" crt, 300watt jensen inverter, USB Keyspan remote) The thing ran fine until I tried to add a USB Earthmate GPS to the system. The inverter whines when everything is plugged in and generally screws up. If I unplug my keyspan remote it fixes the problem, but the inverter still whines now and again. So, can I make my computer draw less power or give my computer more power to work with? I've seen all the stuff on DC-DC conversion, but when it comes to wiring stuff I suck. I've also seen threads on removing some filters on the power supply, but like I said I suck at that stuff. Is there an easy way to do anything? Please help!
    Jul 2000
    Jackson, MS, USA
    Post
    Either you'll have to get rid of GPS or loose some power. Maybe you can under clock the CPU a 100 mhz, or if it has a floppy drive, unplug that. What about the cdrom, do you use it? if not unplug it. 256 of ram, is that 1 stick or 2 128 sticks? If so take out a stick and see if anything changes. You can also drop the voltage on the CPU. What is it, 2.2V? Try 2.15 or 2.1V and see if it still boots.
    [ 12-27-2001: Message edited by: Squeezer ]
    24 y/o w/ Silver/Red
    2000 Honda S2000
    http://www.squeezer.net
    Jul 2001
    Post
    Or, get a bigger inverter??
    Jun 2001
    Washington State
    Post
    I can't say this for sure because I have never used any of their inverters, but Jenson SUCKS! I have had some experience with their amplifiers and stereos and have yet to have a good experience. In each case the stuff works fine (although not as well as they claim) but then craps out after about 8 months worth of use.
    Good luck, and I hope your experience can work out better than any of mine did.
    Oct 2001
    Anniston, AL
    Post
    Anyone know of any good inverters that go over 300 watts? I've purchased 3 different inverters, and they all suck. (Especially the Jensen) I'd rather have some input before i lay down another $100. Also would underclocking my processor really help that much with the voltage? I
    May 2001
    Cincinnati, Ohio
    Post
    Stop by RadioShack we (I'm a store manager there) have a true 300 watt for $99.99 that has 2 AC outlets. It has a fan and a fuse. Should be much better than a jensen.
    Mar 2001
    Post
    Modify your GPS to get power from a seperate dc-dc PS (a very small one, just for the GPS). If it takes ~12vdc natively, then just hook it up to the switched car battery.
    If you've really spent hundreds on inverters.. well.. that sucks. You can get an excellent DC-DC power supply that does 250W for $180. I spent $25 on my 150W inverter (which was more than enough) before replacing it with a DC-DC.
    Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
    Car: 1993 Nissan Maxima, Black Emerald
    Jul 2001
    Post
    I've yet to see a dc-dc ps that can power a bookpc the +5 is fine but for some reason book pc's draw a ****load of power on the +12 rail....
    [ 12-31-2001: Message edited by: Ces///M3 ]
