Results 1 to 6 of 6
Thread: NEED HELP ON ATX SHUTDOWN
    FLAC Mastero's Avatar
    Aug 2001
    India
    Post NEED HELP ON ATX SHUTDOWN
    hey anyone whos built an ATX shutdown ....
    can help me http://www.roshanindustries.com/carm...ges/atxshd.gif
    this is the image i am using but i dont know why the relay is getting a power without me even connecting the ACC ... so i was wondering if you guys could help me on this..?
    mastero
    [ 02-05-2002: Message edited by: mastero ]
    Aug 2001
    India
    Post
    well jeff .. at least you i taught would have some answers ...????? after all its your design ...
    Mastero
    OK i was just going through all the data i have on this and i guess im using 7805 regulator and not 78L05 regulator..
    does that make a difference...?
    Well ??
    [ 02-04-2002: Message edited by: mastero ]
    Oct 1999
    CA, USA
    Post
    No, the 7805 is good for 1A of current, the 78L05 is good for 100mA of current. This is not the reason.
    Apr 2001
    Portland OR
    Post
    Did you give it enough time to charge up all the caps?
    Have you looked through the timing diagrams?
    Does the kill switch work? or work after time to kill has passed?
    The relay is suppose to come on when you first power the device on. This is how the design works.
    Leave it on for 10 minutes, if it hasn't turned off, then start whining.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Aug 2001
    India
    Post
    Now thats better
    ok jeff shall wait for ten min or shall hit the kill button to see wat happens.... !
    MAstero
    Aug 2001
    India
    Post
    Hey thanx for all the help ... problem sloved...
