Results 1 to 10 of 11
Thread: Read the FAQ. Really need your feedback
    LLR
    LLR is offline
    Dec 2005
    Hi!
    I've been reading this board for a while and now I'm ready to take the plunge.
    What I have so far:
    PC:
    -fanless PIII ULTRA LOW VOLTAGE 1.1V, 650Mhz (I didn't find the specs in those highly regarded "power calculators" though. The Intel`s website says it has 8.3W of Thermal Design Power)
    - mobo "with 12V built-in power converter" (by "power converter" they mean power supply, right?)
    -512Mb PC133
    -internal slim CD/DVD drive
    - 20GB Hitachi Endurastar for Extreme Environment, 4200 rps
    -USB mouse
    Although the AC adapter is rated 12v 5A, but what's the REAL total wattage
    here? 40 tops, I guess?
    =======================AND============
    -IR rearview camera that is 5v, 1A = 5W
    -Xanarc 7" with t/screen, 12V with "Power Consumption: <8W" So, lets say it's 8W, and therefore, it's about 0.7A
    Total:13W
    ============PLUS============
    Wifi Access Point. The power supply says it's 5V, 2A (I really need it, not gonna argue here) + Wifi signal Amplifier (12V, 1A)
    So, the total here is 5*2 + 12*1 = 22W
    =============TOTAL is app. 80 W (90 tops), right?=========
    OK. So, I saw that picture in "FAQ: Power Supplies Explained (Part 1)"
    Battery --> Regulator --> startup/shutdown controller --> Power supply --> Computer
    And thought that I could buy one of those "Opus 150W Dual power output" regulators to feed ALL my equipment. It has startup/shutdown controller, doesn't it? Just to save your time I'm posting specs here PLUS how I think it's correct to connect them:
    Output 150W
    +3.3V 10Amax, 13A pk
    +5V 10A max, 13A pk =>IR rearview camera (5v 1A) + Wifi AP (5V 2A) IN PARALLEL
    +12V 5A max, 6.5A pk =>PC (12V 3A) +Wifi Amplifier (12V, 1A)+Xenarc (12V, 0.7A) ALL IN PARALLEL
    -12V 0.5A max, 1.2A pk
    5V standby 1A max, 1.2A pk
    And although the OPUS web site says that it should be like this:
    BUT IN REALITY IT SHOULD BE LIKE THIS
    Battery --> OPUS Regulator (with SSC) -->PC power supply->motherboard
    .................................................. ...-->Wifi Amplifier
    .................................................. ...-->Xenarc 7"
    TIA. Your feedback is highly appreciated.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Startup/Shutdown controller is included in the Opus.
    I'm not sure that I understand your point about the drawing. It seems right to me.
    Want to:
    Elsewhere
    Quote Originally Posted by LLR
    The Opus unit includes both the regulator and the SSC built-in.
    Also, your outline and the opus drawing are the same, unless we're missing something here.
    How about the Wiki?
    LLR
    LLR is offline
    Dec 2005
    Quote Originally Posted by Bugbyte
    Thanks for the quick reply
    Well, the OPUS's drawing shows that the OPUS is DIRECTLY connected to the PC's mobo. What I tried to do is to show that OPUS should be connected to the built-in 12V PC's power supply that is connected to mobo. Right?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    yeah....wtf
    PC Components:
    My work log
    Elsewhere
    NO.
    The Opus has a 20-pin connector that connects directly to the motherboard that feeds all the appropriate voltages the motherboard needs (12v, 5v, 3.3v). That's for an ATX motherboard.
    If you have a PC with an external 'power brick' that accepts 12v input, you might consider a power regulater, like one of the Carnetix products.
    It would also help if we knew what PC you're talking about, rather than just a page full of specs.
    How about the Wiki?
    LLR
    LLR is offline
    Dec 2005
    Quote Originally Posted by DarquePervert
    NO.
    Ok, I have an external 'power brick' that accepts 110v-240V AC input and produces 12V 5A DC that goes into that small plug on the back of my computer
    The full description is here, but Hitachi HD is not sold on their website.
    So after reading the FAQ I thought that I need a regulator (that "is not, per se, a power supply component. It's job is to REGULATE the power" and "Words of wisdom: You need BOTH power regulation AND a power supply if you want your system to work properly and reliably") so that I can have a stable 12V DC that has to be connected to that small plug on the back of the computer
    Am I missing something here?
    Elsewhere
    Nope.
    You're spot on. You do want a regulator. Again, I suggest one of the Carnetix products. The CNX-P1260 should power your Cappucino quite nicely and it also has an integrated SSC.
    The other Carnetix models are the same principal, but have higher power ratings. For example, the CNX-P1290 has additional outputs to enable you to power a screen or external devices like a USB hub or USB optical drive.
    How about the Wiki?
    LLR
    LLR is offline
    Dec 2005
    Gotcha. Thanks.
    One more Q though.
    According to Carnetix P1290 manual, the jumpers settings can be configured for various (and I'm sure very usefull) operating conditions, but there is NO single one that would allow a computer to keep running AFTER the ignition is SWITCHED OFF (the key is removed).
    But I'd like to switch the IGN off and leave my computer running from time to time. (I know, I know - batteries, drainage and all that, but it's not the point here). In order to do that I have to install some sort of a bypass switch, right? So that, say, if switch is on then +12V goes through CArnetix to CarPC, but if it's off - PC connected directly to the battery.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Yes. A bypass switch would perform that function.
    However, you could just leave the keys in the ignition and stop the engine. Most cars will keep the power on until you turn the key to the "off" position or in some cases, take the keys out of the ignition.
    Want to:
  1. Replies: 2
    Last Post: 06-19-2005, 04:18 AM
  2. Read the bible to make your PhoneControl Run!
    By dragonBTV in forum PhoneControl
    Last Post: 04-15-2005, 08:14 AM
  3. drive and read
    By aguila in forum Road Runner
    Last Post: 03-19-2005, 04:46 AM
  4. Using advanced search to read the last 'X' posts
    By Bugbyte in forum General MP3Car Discussion
    Last Post: 03-06-2005, 06:38 PM
  5. How much of the forum do you read?
    By MP3DUB in forum Off Topic
    Last Post: 11-06-2002, 08:32 PM
