Results 1 to 10 of 14
Thread: What does the Opus do when remote goes low but OS not loaded?
    Apr 2005
    Toronto, Ontario
    I don't see this in the manual and can't find this info through a search.
    I'm pretty sure my hard drive was frozen and didn't start spinning up (this was a couple of days ago). When I turned my car off, the Opus didn't shut off.
    Today, I was transferring some files over to the car pc. I rebooted the computer, forgetting that my laptop hdd (in an external enclosure) was connected. The problem with this enclosure is that it probably isn't getting enough power through the bus when the computer starts up, which leads to erratic behaviour. Usually, the device is "detected", but the drive is not available, if it is left connected when the computer boots up (otherwise you just connect it while the OS is loaded and it works great).
    Anyways, when I was testing this behaviour on my laptop, I noticed that one time, during the boot process, Windows pretty much goes to a gray screen and halts, right before you'd be presented with the login screen. Today, the same thing happened with my car pc, but upon turning the car off, the Opus also did not shut off.
    So what does the Opus do, in terms of shutdown control, when you aren't in your OS?
    I waited and it didn't shut off in either situation. The Opus is definitely losing the remote line.
    I thought that the Opus mimicked the case's power button. Why would my computer not shut off in these situations?
    Also, is this similar to what the Opus would do if Windows decided not to shut down? Does the Opus wait a set amount of time and then do a hard shutoff?
    '03 Intensa Blue Pearl Lexus IS300
    Specs: Xenarc 700TS, Opus 150W PSU, CarCPU Case, 2.0 GHz Celeron D, DFI PS-35-BL, SB Audigy2 NX, Centrafuse 1.4
    Progress: Car PC up and running!
    To Do: Navigation, WiFi, AM/FM Radio, DVD
    Apr 2005
    Toronto, Ontario
    No ideas?
    Banned rev2's Avatar
    Dec 2005
    It will wait for a while, and then do a hard-off.
    Apr 2005
    Toronto, Ontario
    Is there any chance that you know how long "a while" is though? Have you ever tested it?
    Elsewhere
    Have you considered asking the fine folks at Opus Solutions?
    It's their product, after all...
    How about the Wiki?
    Apr 2005
    Toronto, Ontario
    Quote Originally Posted by DarquePervert
    Yup, I'm just waiting for a bit more input before shooting off the email. But it's on my to do list if this doesn't turn up the answer.
    I'll definitely post the response here in this thread for future reference in case anyone else is searching for the answer.
    Dec 2005
    Quote Originally Posted by azzurro
    IIRC its the turnoff period after you take out your key.
    Apr 2005
    Toronto, Ontario
    Quote Originally Posted by rev2
    Mine is set at 10 seconds, but it most definitely didn't obey...
    Dec 2005
    Damn.
    Sorry I couldn't be more help
    Apr 2005
    Toronto, Ontario
    Damn.
    Thanks for trying though
    If no one has any other input, I'll be contacting Opus.
  1. Opus = Best, but will ITPS suffice for low end?
    By cybermob2 in forum Power Supplies
    Last Post: 05-17-2004, 01:55 AM
  2. opus resistor for low power cutoff?
    By 00CericaRuss in forum Power Supplies
    Last Post: 03-08-2004, 03:49 PM
  3. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  4. Replies: 6
    Last Post: 11-25-2003, 12:27 AM
  5. Which OS for a low spec Machine??
    By jakeep in forum Software & Software Development
    Last Post: 10-24-2003, 06:54 PM
