Results 1 to 5 of 5
Thread: Need a Good Power Inverter - Need Ideas
    Oct 2001
    Anniston, AL
    Post Need a Good Power Inverter - Need Ideas
    I'm looking for a good power inverter, and I need some direction in what brand etc to take. I'm needing an inverter that is over 300 watts and doesn't have any alarms when voltage peaks. (Such as the crappy Jensen inverter) I'm also looking for one that doesn't have much height. ( Less that 2 inches) Finally I want it to have the standard 12v cigarette lighter adapter. Any ideas?
    Apr 2001
    Portland OR
    Post
    Well a 300 watt inverter on a cigarette lighter outlet is a bad idea. The wire that typically goes to the cigarette lighter is not very heavy gauge. At 300 watts you will be pulling 25 amps!!! In my car, I have a 20 amp fuse on the cigarette circuit, and there are other things on that circuit too. What are you powering that needs so much power?
    Jeff
    [ 12-31-2001: Message edited by: Jeff Mucha ]
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Apr 2001
    Portland OR
    Post
    Hey what processor are you using? Are you using a celeron 500? Socket 370?
    www.mpegbox.com
    Oct 2001
    Anniston, AL
    Post
    I'm running a BookPC with an Intel Celeron 500mhz socket 370. Also have some USB peripherals and a CRT I have to connect.
    Apr 2001
    Here, There, Everywhere
    Post
    Originally posted by wallachee:
    <STRONG>I'm running a BookPC with an Intel Celeron 500mhz socket 370. Also have some USB peripherals and a CRT I have to connect.</STRONG>
    argh!! When you say CRT you mean a good-old-fashioned SVGA computer monitor? Dont go running a CRT monitor off a car system.... your asking for trubble.!!!
    well it explains the 300W!
    Project - GAME OVER :(
