I have an inverter and also clear audio!
I just grounded everything and the noise was gone.
Im just wondered how people have managed to get perfect sounds when using an invertor, getting rid of noise.
I know earthing the Power supply can do it
So can using a ground loop isolator and a low pass filter / active crossover..
Any other ways?
jose
http://oacar.mp3car.com http://faq.mp3car.com
John McLear - John@minerva-centre.com
http://www.205oc.co.uk
UK Mp3car slapnut
#mp3car - Efnet
Carplayer and Mediaengine *****
spank gemma.co.uk for holding my motherboard for so long. still no board, wood work nearly done :|
[-----------(90%)----] Completed :)
pics at: http://www.zcentric.com/~mitcht/gall...me=Convertable
GROUND LOOP ISOLATOR
Get one now.
I've NEVER heard an inverter noise after running one of these in the line. Power line filters are crap too. Get a GLI.
Public PGP key available on http://keyserver.pgp.com/pks/lookup?...@MyRealBox.com
I think im one of the few people that used an inverter (and always have) and have never had a problem with noise with it. Its a statpower ProWattz 150watt inverter, and it works great.. NEVER have had any noise.. It was a bit more expensive but it works perfectly.
Now, I used a Statpower PortaWattz 1400watt inverter for a bit in the middle and it buzzed like hell until I grounded it.. but it was a much cheaper inverter.. The quality really matters.
Of course I would prefer to move to a DC-DC supply at some point, but the inverter does work perfectly well if you don't want to go that route.
when i was testing saturday i had absolutely no inverter noise, over a pair of headphones.
i Haven't had a chance to check it out with the tape adapter
only time will tell
headphones won't do it, as you don't have a ground loop using headphones.. the grounloop is created when the computer and the radio are connected.
anyway. I have GLI and it helps, but the PSU or Case has to be grounded (i use the same cround point as the inverter and amp) for it to be crystal clear. Plus my sound card has a Signal to Noise of 90 dB... that helps.![]()
I cheat, I own an empeg.
Meskimen's Law: There's never time to do it right, but there's always time to do it over.
http://civic.mp3car.com
okey let me rephrase
If you guys are using tape adapters and the like you wont hardly notice it.
My Sound goes straight into my amps
jack - 2x rca
then it goes to gli
its when i have both amps plugged in i get an buzzing
if one of em is plugged in its fine.
And if the jack aint in the PC again its fine, weird eh
UK Mp3car slapnut
#mp3car - Efnet
I had the same problem with tape adapters. Only I had a high pitched noise and it got higher with the amount of RPMs. The only thing I could figure is that when the engine's RPMs increase so does the alternators output (ie.. step on the gas and more power is generated), and that power is going to the source of your music, (computer, cd player w/cig lighter plug, etc..) and then into your stereo. That noise totally stopped when I got a FM modulator. I highly recommend using one if you dont have audio inputs for your stereo. (BTW I am using it for a portable CD player right now)I use an inverter and a tape adaptor, I have no inverter noise, when the computer is on, but when the computer is off, I get a ticking sound that is from my engine (i.e. I give more gas faster ticking)
As for inverter noise I don't have my computer installed nor do I have an inverter yet. But I have planned the whole grounding situation out. When I built the computer case (check it out and tell me what you think) I added a bannana plug input and wired the hard drive, motherboard, and power supply to it. So when I go to install I just have to plug in the bannana plug that has been grounded to the cars body. And since the inverters ground will be attached to the body I shouldn't have a problem. If I do then GLI all the way!
BTW Jose I just noticed our member numbers 1339 and 1338. Cool![]()
http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
A guy by the name of BJ talks about removing the "phase correction capacitors" from a standard 110/220 PSU to remove noise, his website is at http://home.primus.com.au/bravo/
this info is on his "Projects" page under the link "BJBlaster car MP3 Player" then the "Power Supply" link. Have not tried this yet, but it seem's reasonable.
