Results 1 to 6 of 6
Thread: Convert Arise AT to ATX?
    Jun 2000
    Post Convert Arise AT to ATX?
    I was curious, would it be possible to convert the arise DC/DC AT power supply to ATX? Perhaps using a 8-16VDC to 3.3V converter on one of the 12V lines then rewiring the cable to a standard ATX P1 connector?
    I know u wouldnt get auto turn on or soft off but if u manually turned the unit on or off it would turn the board on would it not?
    Shawn
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    How much 3.3V power is needed? You can connect an LM series regulator to the 5V line (keeps power dissipation low) instead of the input of the supply. There are TO-3 style regulators which will do 5A.
    Jun 2000
    Post
    Hi Aaron,
    Thanks for the info. Any idea where the regulators are available? I have the AT and ATX power specifications here, in a perfect world all we should have to do is rewire the cable, add the regulator and be on the way.
    Shawn
    Jun 2000
    Post
    Hey Aaron,
    Any idea what the required current is for an ATX motherboard? Maxim makes many step down converters for the 5V to 3.3V DC but they are all at different amperages. Any idea?
    Shawn
    Apr 2001
    NJ, USA
    Post
    Actually, you'd be better off taking one of the 5V lines and using that for the 3.3V. On my AC/DC in my current home PC the psu MAX rating for 3.3Vo is 10A. Of course, it's probably not using all 10A but the most amperage out from a 3.3V regulator on Digikey or Mouser I've seen is 2A, and that's max. I'm starting to think the Dc/Dc convertor just ain't gonna happen for me. Look like the DC/AC/PSU is more a reality for me at this time.
    P4 2.4GHz, Intel mobo w/onboard sound & video, 128MB memory, 100GB Seagate Momentus laptop drive, Xenarc 700TSV 7" touchscreen, IRman using Girder, 150W Opus dc/dc psu, Alpine CDA-9835 h/u, MBQuart speakers, Infinity 15" sub, MTX amps.
    Jan 2000
    Cool
    Sounds like you won't need more then 5A at 3.3V. Take a look at the LM338K. This an adjustable regulator in a TO-3 package that can handle a maximum of 5A.
