Results 1 to 5 of 5
Thread: inverter timer shutdown
    Dec 2005
    Ok I've been reading posts all day and still cant find a clear solution.All I want is to have my inverter be powered up with ignition and then when I manually push power button to shutdown carputer I want the inverter to stay on for a few minutes then turn off.Something like a turbo timer for the power inverter.
    Elsewhere
    This isn't all that difficult.
    Although I don't know the exact parts & wiring, you can pull this off with relays. The PC itself can be setup to power on as soon as it receives power. The setting for this is in the BIOS. Wire the power buttin for the PC to wherever you want it. With WinXP, a simple press of the power switch will initiate a proper shutdown.
    For speed of startup/shutdown, you might want to consider hibernation instead of full startup/shutdown.
    How about the Wiki?
    Dec 2005
    I want to start and shutdown the pc with a push button.Thats not a problem.But what I want to do is have the inverter on a timer so power is cut from it like for example 2 mins after I turn the car off.
    Can the $42 sdc do this? Can it control the power to the inverter?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by aceboogie
    Yes, the 42 dollar SDC will do it. Almost any SDC will, it is just a matter of connecting it correctly. That is the trick.
    You can also use this http://www.caraudio-caralarms.com/528T.html (I searched the forum and found the part number, then did a google search for it) Check out the last application on the bottom of the page.
    Michael
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Why not have the inverter power off when the computer turns off?
    Someone made a neat diagram showing this, I believe it went like this:
    Code:
                                   |--ground
    Bat ------o/o (relay)-------inverter-----computer
                   ~~~~~~~-ground (computer also needs to be grounded)
                   |---------diode
                diode             |
                  |               ignition wire
    computer 12 v out
    So as long as the computer is on or the ignition is on the inverter is connected to the car battery and the computer keeps going. Then just make the computer know when the car is on/off with one of them software shutdown controlers and it can hibernate itself, which in turn cuts power to the inverter after its done.
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
  1. WTB: Coleman Inverter with Shutdown controller
    By PDiddy in forum Classified Archive
    Last Post: 06-28-2005, 05:23 PM
  2. Inverter and shutdown controller
    By gboy in forum Power Supplies
    Last Post: 03-01-2005, 06:48 PM
  3. custom shutdown controller for inverter usage
    By Vchat20 in forum Power Supplies
    Last Post: 02-28-2005, 11:59 PM
  4. Shutdown / Start up controller with an inverter?
    By Skipjacks in forum Power Supplies
    Last Post: 12-18-2004, 08:56 PM
  5. Plz help me with shutdown + inverter....I'm almost there.
    By falconey in forum Power Supplies
    Last Post: 09-09-2004, 12:06 PM
