Results 1 to 7 of 7
Thread: Will M1-ATX power this setup
    Sep 2005
    Israel
    Hi,
    I read and read and searched but could not find anything to give me a definite answer. Can M1-ATX power supply power this configuration:
    Epia SP-13000
    512 MB 1 stick RAM
    120 GB 3.5" SATA disk
    7" Liliput touchscreen
    USB GPC Mouse (BU-353)
    Panasonic Slot Load DVD-ROM/CD-RW Combo Drive
    If not then which power supply would I need?
    Thank you for an answer.
    Efim
    Elsewhere
    You didn't very hard then.
    There's dozens of users with a similar setup to what you're using. Yes, the M1-ATX will power that just fine.
    If you want more overhead for future devices and/or upgrades, then get a beefier PSU like an Opus 150w.
    How about the Wiki?
    Admin
    Aug 2005
    I would *not* say that the M1-ATX will power this "just fine" as you'll be pushing the 12V rail to it's limits with this setup. If you go the M1-ATX route, it wouldn't be a bad idea to put a meter on your 12V rail to see what you are actually drawing and you'll *definitely* want to do this before adding any additional 12V devices.
    -g.
    Sep 2005
    Israel
    gnomad, which PSU would you suggest for such a setup?
    Constant Bitrate RawsonDR's Avatar
    Dec 2005
    Dayton, OH
    The creator of the M1-ATX is about to release a second version, the M2-ATX. It will be mostly the same with increased 12v output (2A to 8A). This is what I plan on using for my first build.
    Samples of M2-ATX
    May 2005
    San Clemente, CA
    You would be fine with an M1-ATX, though.
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
    Maximum Bitrate kbyrd's Avatar
    Nov 2003
    Northern Arizona
    Quote Originally Posted by gnomad
    -g.
    I googled "sp13000 power calculator" and found this after a couple of clicks. It's that 3.5" hard drive that puts you over. It draws a bunch of 12V.
    My worklog.
    Status: VM GTI sold, got out of the CarPC tinkering hobby, but I still think about getting back in.
  1. POWMAX Mini ATX power supply - Power on leads?
    By e30_droptop in forum Power Supplies
    Last Post: 10-18-2005, 08:50 PM
  2. atx POWER SUPPLY?
    By nickweb in forum Newbie
    Last Post: 09-26-2005, 04:39 AM
  3. WTB: Micro ATX power supply
    By mykolJay in forum Classified Archive
    Last Post: 06-13-2005, 04:12 AM
  4. fs: mastero mk-3.5 120w atx dc-dc power supply
    By infinkc in forum Classified Archive
    Last Post: 05-16-2004, 06:06 PM
  5. What are the ATX DC to DC power supply options?
    By Squeezer in forum Power Supplies
    Last Post: 07-08-2002, 04:25 PM
