Results 1 to 10 of 16
Thread: Opus shutdowns while car is running.
    Feb 2004
    Specs.
    1.2 ghz
    256 ram
    80gb hardrive
    5 usb devices (touchscreen, gps, remote control, shuttlexpress, WLAN)
    optima red top battery
    The issue is that my Opus 150 is detecting a low battery and pulsing the power button (hibernating my carputer) while the car is on. This usually early in the day when i first start my car, while sitting in stoplight traffic for maybe 5 minutes. It will also happens after i have driven the car for a while, and try to listen to music while the car is in running in park, after about 10 minutes.
    I'm guessing my issue is:
    1. the detection level for auto-shutdown when the battery level is low for the opus is too high, and is initiating shutdown before i need it.
    2. Leaving my carputer in hibernation all the time is draining my battery to such a low level that it never really gets fully charged in the morning or during the day, causing the battery level to reach the opus level for shutdown sooner than normal.
    How do I tell what the real problem is, and how do I solve the problem?
    thanks
    note: I used to have 500 posts, and then my account got cleared...
    Feb 2004
    North Aurora, IL
    how old is your battery?
    maybe its not holding a charge anymore... just a suggestion.
    I wish i knew how to do fiberglass work...
    May 2005
    I have the same problem with M1 ATX 90W. Epia M10000, I have Lilli on M1ATX, GPS mouse, 120Gb 3,5", 512Mb and PCI Wireless and dont have any CD ROM.
    Ive tried to change the car battery but the problem stays.
    I think, that maybe is problem in my hard disk 3,5". HOpe so. Any idea?
    Feb 2004
    Quote Originally Posted by theheel
    I had the same problem with my old battery so I bought my optima red-top,
    The same problem before and after new battery.
    Oct 2004
    NY
    put a voltmeter on the battery while running..... if your seeing anything less than 13.5-13.6v you have an alternator problem.... if more then check all connections to the opus... a bad ground can cause this, along with a shoddy power connection....
    if the opus is seeing well over 13v & still shutting down then the opus has an issue
    Feb 2004
    ok, just got back from my voltometer test.
    Idle = 13.9 V
    Idle + Radiator Fan from air =12 V (about)
    Idle + Radiotor + Headlights =11.5V (about)
    The problem tends to happen more in the winter, which I now know is a correlation to me blasting the heat on full.
    Conclusion: Opus is fine,
    Does the data provide conclude that the problem is my alternator?
    Is it a "problem" or just not powerful enough?
    Oct 2004
    NY
    a bad battery can give the same results, but I don't think it would reach 13.9 at idle if it was a bad battery.... start the car, then with it running disconnect a battery terminal.... if the car dies then the alternator isn't charging.... if the voltage at the terminal goes up then the battery may be no good, you'd need to load test it to confirm
    yours just sounds like it can't deliver enough amperage under load... check the connections at the alternator & battery.... it may just be a weak alternator or a bad connection, what kind of car is it? how many miles... how old is the battery....
    Feb 2004
    2002
    Subaru
    2.5 RS Impreza
    1 Year old Optima Red-top
    I'll get back to you after I try the test you suggested,
    Thanks again for the help
    Feb 2004
    Alright, the Results are in:
    Car runs after dissconnecting a battery terminal
    Voltage Decreased after disconnecting terminal
    Conclusion:
    as you said alternator "can't deliver enough amperage under load"
    Solution: Check Connections; Buy a new Alternator
    Question:
    How do I make sure I buy an alternator that will deliver the right amount amperage?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    You may have a bad ground between the chassis and the battery.
  1. Replies: 17
    Last Post: 02-17-2006, 05:59 PM
  2. PC wont boot while car runs
    By Empreez in forum Power Supplies
    Last Post: 11-30-2005, 05:25 AM
  3. Ituner M1-ATX vs Opus 90W Car PSU
    By RickSeymour in forum Power Supplies
    Last Post: 07-27-2005, 09:55 AM
  4. Real Time Car tracking now working!
    By Magpie in forum GPS
    Last Post: 10-27-2004, 05:08 AM
  5. Replies: 9
    Last Post: 11-01-2002, 12:21 PM
