Results 1 to 10 of 11
Thread: HP E-PC Power
    Nov 2005
    HP E-PC Power
    I do not understand what the big deal is over powering the HP E-PC.
    The specs on my AC power supply read:
    INPUT - 120-240V ~ 1.8A 50/60 Hz
    OUTPUT - 19V =-=-= 3.16A
    The specs on the notebook power supply I just bought reads:
    INPUT - 10-15V =-=-= 6.5A
    Should work just fine. I have 3 of these E-PCs, each with 10gig HD, 128mb RAM
    One will be for sale by the way very soon.
    Jul 2004
    clarification on the powering the e-PC
    The question really is how do you power a HP e-PC without using the brick. Because the e-PC only uses a direct plug/brick and not a 20-pin plug that goes to a power supply like other PC's or VIA mini-ATX boards.
    How will you plug a M1-ATX or M2-ATX to the HP e-PC if it doesnt have a plug for a 20-pin ATX plug? that is the question...!!!
    FLAC evandude's Avatar
    Mar 2005
    Maine
    Quote Originally Posted by ejcpv
    first off, this thread is a few months old. Second, I don't see what the problem is. he has a new brick that plugs into the cigarette lighter and powers the computer. the computer clearly has a power supply built in that directly accepts power from this brick, via a simple barrel connector, and provides power to everything internally. There is no need for an ATX power supply in that situation.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Registered User
    May 2003
    Exactly,
    Thats what make it easier because the e-pc uses a AC adaptor/brick/PSU similiar to laptops.
    The AC adaptor outputs 19V @ 3.16A max. All thats needed is a car-laptop adaptor thats rated at 19V @ 3.16A or more.
    I dont understand where that M1-ATX or M2-ATX comes in because the MB will just take 19V directly and it will work, infact its perfect for a car PC because they are cheap and easy to power.
    If you look at the second picture, that PSU + SDC and your car PC is virtually complete.
    Those car-laptop adaptor input voltage is normally from 10V, this is not low enough to survive a crank reliably. I havent seen any of those adaptor that will accept from 8V-16V.
    Nov 2003
    Marietta, GA
    The CarNetix P1900 should work well for this application. It survives engine cranking and has a startup/shutdwon controller. It also has a secondary output if you need to power your screen or USB hub.
    http://www.carnetix.com/CNXP1900.htm
    MikeH
    Feb 2006
    Colorado Springs
    Just a heads up:
    The P4 versions of the HP E-PC have a large requirement off the 12V line to power the P4 CPU. The P1900 CAN NOT supply enough power on the 12V rail by itself.
    If you have any other version of the E-PC, you'll be OK.
    EDIT: The power brick from the P4 versions say output of 4500mA at 12V
    Oct 2006
    San Antonio, TX
    Quote Originally Posted by Lurieh View Post
    Just a heads up:
    Can this be confirmed?? I've been searching, but this is the only post that says an E-PC 42 won't work with a carnetix 1900
    Hardware: [-------- ]30%
    Software: [----- ]20%
    Install:[------- ]70%
    2005 Subaru WRX - New 1.83 GHz Mac Mini - OSX/parallels is my front end - K301 InDash monitor
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Quote Originally Posted by OUSilver05 View Post
    <most of this is from a different post>
    Ok, my setup has the E-PC/40 PSU feeding the PC via a cheap terminal strip.
    I did this to figure out how much current each of the supplies was providing.
    I made these measurements, and also looked at the power good signal.
    I found the following, peak load conditions;
    19v supply 1.3 Amps
    12v supply 4.2 Amps * not compatible with carnetix 1900 spec *
    FYI's
    I also have a E-PC/42 which I rejected as an upgrade since it draws too much power and adds no functionality.
    I've used a carnetix 1290 along with a laptop 19v psu but went back to the inverter/brick because I like it's audible low batt alarm, and the ease of plugging in the ac brick.
    Apr 2009
    Quote Originally Posted by ejcpv View Post
    I am a bit confused, can we power the e-pc 42 with M2 ATX, yes or no??? I have similar issue but in my case I bought the M2 ATX PSU ..and I am still wondering if this can power up my e-pc or not
    May 2009
    ey,
    I was, also, wondering if it's possible to use ONLY the 12v rail from a M2-ATX, or any picoPSU...?
    thx,
    Hans
  1. Car power supply (battery charger) from old pc supply
    By stimps in forum Power Supplies
    Last Post: 08-20-2010, 12:39 AM
  2. Replies: 3
    Last Post: 10-28-2005, 04:43 PM
  3. 150w PC 300w Power inverter... help?? Please..
    By MINI-Cooper-S in forum Power Supplies
    Last Post: 03-16-2005, 06:25 AM
  4. PC power off after playing Divx
    By hakira007 in forum General MP3Car Discussion
    Last Post: 03-03-2005, 09:54 AM
  5. Can't power LCD and PC at same time?
    By SBDJ in forum Power Supplies
    Last Post: 11-10-2004, 08:06 PM
