Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: wiring 528T timer
  1. #11
    Dec 2004
    working like a charm, in terms of timing, so now onto my next problem.
    That relay was for a mi1atx, whose sole job atm is running a hdd (laptop runs of seperate dcdc supply. I have the m1atx in dumb mode, with no jumpers (as that timed relay is controlling shutdown of psu etc.etc.) but it wont run my hard drive.
    Input is good at ~13.9v, but then the power on the rails in insufficent. With nothing hooked up, the yellow 12v line output around 8v, why would that be?
    Im gonna do some further reading, but i want to get this in tonight and cannot think what could cause it. The output for a led is outputting 6v when the car turns on, so i know the m1atx is functional, but yeah.
    Any help appreciated
    Progress 50%
    Next Step: Making Enclosure, Hard Wiring PSU
    Thinkpad 1Ghz P3
    256MB RAM
    Lilliput Motorised
    80GB 3.5"
  2. #12
    Oct 2004
    NY
    check grounds & all connections... if you have almost 14v in & a GOOD SOLID ground, then there may be a problem with the ps itself....
  3. #13
    Jun 2005
    I am using one of those timer, I found 90 seconds is not enough, I am wondering if I can modified the timer. I would say 5 mins is good. Any electronic guru here?
  4. #14
    Oct 2004
    NY
    you can use a pac-tr7.... it is much more adjustable, but a little complicated to program..... get one & the instructions will tell you all you need to know..... very versital tool that pac tr-7.... it can do alot..... it is most popular as an alpine video lockout bypass module, but it can do so much more....
  5. #15
    Jun 2005
    Quote Originally Posted by turbocad6
    TurboCad, does pac-tr7 has a build in relay?
  6. #16
    Oct 2004
    NY
    yes, it is a relay & a programable control assy in one small black box with a bunch of wires sticking out.... really cool piece & very versitale...
  7. #17
    Jun 2005
    Do you know what the relay rated? 30amp?
  1. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 02:56 PM
  2. Timer Circuit
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 11-04-2005, 10:47 AM
  3. Wiring in dash screen: How-to...
    By marzman in forum LCD/Display
    Last Post: 05-29-2005, 08:38 PM
  4. Wiring Xenarc to wiring harness?
    By deftones8769 in forum Power Supplies
    Last Post: 04-10-2005, 10:07 AM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
