Results 1 to 10 of 17
Thread: wiring 528T timer
    Dec 2004
    wiring 528T timer
    Hey
    i bought a 528T to keep my 1 atx (havnt got it yet) running for 90 seconds after IGN off, to allow laptop (on seperate PSU) time to hibernate and still access drives and accessories.
    The wires are:
    Orange 87A: NC
    Brown 87: NO
    Yellow 30: Common
    B&W: Trigger
    Black: Ground
    Red: 12VDC ground
    Blue Loop: UNCUT - trigger upon receiving negative
    CUT - Trigger upon negative going away
    I need it to come straight on with accessories line, but wait the 90 seconds when the accesories line disapears.
    I though that
    Yelow: Power from battery
    Orange: Wire nothing
    Brown: Wire to M1atx so it closes when triggered
    BW: Accesries line to act as trigger
    black and red; 12v ground
    But when i do it like that, brown always get 12V regardless of ignition, so any ideas?
    Progress 50%
    Next Step: Making Enclosure, Hard Wiring PSU
    Thinkpad 1Ghz P3
    256MB RAM
    Lilliput Motorised
    80GB 3.5"
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    If the brown and yellow are disconnected (NO), then why are you getting 12v out of the brown wire?
    It might have something to do with your trigger wire. The trigger wire might be receiving a 12V+ instead of a negative. So you can use a relay to change the signal received by the 528T to a negative.
    Dec 2004
    yeah sorry it was the orange that was always 12v
    any ideas?
    Progress 50%
    Thinkpad 1Ghz P3
    256MB RAM
    Lilliput Motorised
    80GB 3.5"
    Dec 2003
    Edmond, Oklahoma
    You said that the trigger is triggered on a negative but you are sending it a 12V+ from the accessory. I don't know if that's causing any problems.
    Other than that, it looks like the way you have it hooked up currently should work. The ground (from the relay I was talking about) triggers the brown wire that is normally disconnected from the yellow to close, giving you 12V+ for as long as you set it for. After the desired amount of time the relay will go back to it's orginally state (brown wire disconnected).
    Oct 2004
    NY
    Quote Originally Posted by McGinty
    The wires are:
    Orange 87A: NC
    Brown 87: NO
    Yellow 30: Common
    B&W: Trigger
    Black: Ground
    Red: 12VDC ground
    that is wrong..... it should be: red=12vdc (+)
    Dec 2004
    yeah i just re-read and it says
    +12VDC Ground, so obviously a mistake. This should go to my battery right? and the accesories line to the trigger to switch on/off
    Cheers
    Progress 50%
    Thinkpad 1Ghz P3
    256MB RAM
    Lilliput Motorised
    80GB 3.5"
    Dec 2003
    Edmond, Oklahoma
    Yeah, you got it... the red needs to be connected to a 12V+ from your battery.
    Dec 2004
    ok i have done that and it is functional, but not really how i want it to run
    Now, the orange wire has 12v when car is off
    the orange wire has 12v when car is on
    brown wire has 12v for 90 secs when car is off
    BUT i need the brown wire to have 12v when is ON and for the 90 seconds after it switches off, then have 12v to orange the rest of the time cos its not hooked up to anything.
    Alternate ways of achieving this i thought:
    Have a relay, and join the ACC and BROWN together at the relay. That way, ACC will keep it connected when car is on, BROWN will keep it connected for 90seconds after, and it wont be connected for the rest of the time. This seems plausible, but i am concerned that then it will **** with my other ACC relay which tells the laptop to hibernate when car turns off. I am thinking that with the brown giving 12v, the laptop wont hibernate till after 90sec, defeating the purpose.
    Any Ideas? I am doing the install today, so these delays are gay
    Progress 50%
    Thinkpad 1Ghz P3
    256MB RAM
    Lilliput Motorised
    80GB 3.5"
    Oct 2004
    NY
    use a relay, have it activated with ign, & also activated with the timer.... BUT you will need to also use a diode so the timer doen't back feed the ign.... the diode should go in the ign feed....
    Dec 2004
    ah diodes, now i remember them
    Thank You kindly, because that feedback was what i was worried about, thanks killer-bee
    Progress 50%
    Thinkpad 1Ghz P3
    256MB RAM
    Lilliput Motorised
    80GB 3.5"
  1. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 02:56 PM
  2. Timer Circuit
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 11-04-2005, 10:47 AM
  3. Wiring in dash screen: How-to...
    By marzman in forum LCD/Display
    Last Post: 05-29-2005, 08:38 PM
  4. Wiring Xenarc to wiring harness?
    By deftones8769 in forum Power Supplies
    Last Post: 04-10-2005, 10:07 AM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
