Anything designed to be powered by a car's battery will work with any 12V A/C adapter of sufficient current output. Just make sure that the A/C adapter can output the amperage the LCD requires, and that you've got the polarity right (positive to positive, ground to negative), and don't reverse it.
You may need to pull the tip off the adapter to make it work. You can get multifunction adapters at Radio Shack or Fry's Electronics.
LinkBack URL
About LinkBacks
