This is some nice info to read...Thx
I thought you might be interested in this data...
We have a temperature test chamber where we test all our products -- the other day I did some testing on few popular mini-ITX motherboards and our M2-ATX power supply.
Cold_start = board will turn on
Cold_ride = start at 0C, ride temperature down
While all = boards worked OK on the high tem rage (up to 75-85C) here is what they did on the low temp end:
Model Cold_Start Cold_ride
motherboard
EPIA-5000 -30C -42C
EPIA-M10 K -35C -42C
EPIA-MII-10K -15C -42C
power supply
M1-ATX -42 -42C
M2-ATX -42 -42C
-42C is the lowest temp I can get with this test chamber.
All motherboards started to freak out around 0 C when heavy condensation occured. Forced air (fan) over the motherboard removed the condesation and no more crashes occured. Please note that I obtained this heavy condesnsation by opening / closing the door several times, this kind of violent humidity fluctuations are less likely in a car and that can be easily dealt with by blowing air over the motherboard (some 40x40 mm fans)
I did test a seagate laptop drive to -10C and then I stopped, was worried about data damage, that was a HDD with real data on it...
-Andrei
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
The tolerances for temperature shown by the hardware far exceeds the temperature range that can be survived by this driver!
When it gets below -15C or above 75C, I would be more worried about my body parts than any hunk of electronic equipment. Ditto for debates about the G-forces that can be tolerated.
Still, thanks for posting that information.
What are you talking about? It was -19C here this morning and I have not seen any corpses on streets![]()
Must be someone talking from california. Anything below 0ºC is unbearableOriginally Posted by LagunaICE
Moscow and inland Russia are in a worse situation... They're looking at -31°C around the 20th and 21st of this month.Originally Posted by LagunaICE
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
Good thing we don't live around that area anymoreOriginally Posted by DJiK
we? who else do you mean?
<I declare this thread HI-JACKED>
He's russian. I'm ukrainian. Nuff saidOriginally Posted by LagunaICE
