Results 1 to 10 of 16
Thread: Correct wire gauge for inverter?
    Low Bitrate silveralt's Avatar
    Dec 2005
    Question Correct wire gauge for inverter?
    I'm extending the outlets on my inverter from my trunk to my console. My inverter is a 400/800 watt. I bought some 12 guage wire to use. I figured I should ask first if this is the correct thing to use for the power wire. Thanx for the help.
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    No, you definitely want thicker gauge wire. I would probably go with 4 or 2 gauge for that, although you might get away with 8 gauge.
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    Have you thought about just using extension cables?
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
    Dec 2005
    I guess I will just go for the extension chord. I used 8 ga for the power and ground on the inverter.
    May 2005
    8 gauge is fine for the battery to the inverter..you actually could have used 10 gauge if you really wanted.
    12 gauge is fine from the inverter, to where ever you want to relocate the outlets.
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
    Dec 2005
    Should I put an inline fuse in the extension chord? I planned on doing that when I ran the wires from inverter to outlets in the front of my car.
    May 2005
    Quote Originally Posted by silveralt
    It wont hurt. Chances are your inverter has some kind of built in protection, but it's always a good idea to be extra safe.
    Look in your manual to see what the current rating is on the AC output side of the inverter, it shouldn't exceed 15 - 20 amps, so chances are you'll need a 15 amp fuse.
    status: Totaled
    Aug 2005
    Quote Originally Posted by Rocky388
    Are you kidding?
    YES, PUT A FUSE IN LINE CLOSE TO THE BATTERY. Fuses aren't put in the power wire to protect your equipment, they're put there to keep you from diaf.
    In the works...
    Dell GX240 SFF
    P4 1.8GHz, 256 RAM, 160GB HDD
    8" Lilliput (fab work completed - F-150)
    My worklog
    Misc crap FS - OLD laptop (w/ adapters) | Sony memory | USB key | Printer Dock, etc
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by SMOKINV8
    Are you kidding?
    I think they're talking about the wire from the inverter to the equipment, not from the batt to the inverter.
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    Quote Originally Posted by mushin
    lets hope so, otherwise he's in for a carpet fire at the least.
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
  1. what gauge wire to run from fuse block to trunk?
    By MP3GTP in forum General Hardware Discussion
    Last Post: 03-30-2005, 05:17 PM
  2. lengthening fm transmittor antenna wire
    By hand in forum General Hardware Discussion
    Last Post: 03-24-2005, 11:21 PM
  3. What Gauge wires do I use?
    By Showmehow in forum Newbie
    Last Post: 07-25-2004, 11:41 AM
  4. 8 gauge wire BIG!?
    By detz in forum General Hardware Discussion
    Last Post: 07-11-2002, 03:23 PM
  5. question about relays and high gauge wires
    By Heedunk in forum General MP3Car Discussion
    Last Post: 05-10-2001, 12:13 PM
