Results 1 to 10 of 12
Thread: m2-atx & 2 amp remote connections?
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Question m2-atx & 2 amp remote connections?
    I tried searching but couldn't find anything.
    How could you connect the m2-atx to 2 amps. Can i split the wire to both of them or will the current be insufficient??
    May 2005
    I could be wrong, but the current on the remote wire is going to be minimal anyway..it's not the current you're worried about. It's the voltage drop, and Unless your run is really long, again, I can't imagine that being an issue either.
    So yes, split the wire in 2.
    It might be easier to go from the m2-atx to your first amp, and from your first amp to your second...instead of 2 wires going from the m2-atx to both amps...just something to consider.
    Take 2 - '03 Audi A4
    macmini with an 8" widescreen (in progress)
    My 2004 Ford Ranger:
    14" LCD w/ custom made aluminum bezel
    Completly custom computer case
    status: Totaled
    haf
    haf is offline
    Newbie haf's Avatar
    Jan 2006
    Athens
    I have the same problem. I tried to connect with the same wire the two amplifiers but nothing happened. I think that might be a voltage drop.
    Nov 2005
    Quote Originally Posted by haf
    you could always use a spdt relay to send a +12v remote signal to your amps
    haf
    haf is offline
    Newbie haf's Avatar
    Jan 2006
    Athens
    Quote Originally Posted by 99blkprotegelx
    I had in mind to make my self a relay suppling 12 V but how i can make the delay.Sorry what means "spdt". Whre I can find something like this.
    Thanks in advance
    PIII, Intel 733Hz, 256Ram, DVD/CD-RW, 60GB HD, SoundBlaster X-Fi, TV Tuner, M2-ATX, BT
    Maximum Bitrate LiquidKernel's Avatar
    Feb 2005
    Single-Pole, Double-Throw... it's a switch layout.
    Aug 2005
    Pennsylvania
    You can just run the remote wire form one amp to the other amp. Works fine for me and never had a problem with it.
    Sharjah, Emirates
    Quote Originally Posted by volum3rider
    doesn't that cause a voltage drop, or do amps accept a wide range of voltages for remote input?
    Aug 2005
    Pennsylvania
    Quote Originally Posted by ramy_zohair
    To my knowledge, it probably does create a voltage drop but then again the remote wire connection on subs and almost every other car audio device only needs a 5 volt signal. I think that they do accept a wide range of voltages.
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    the remote/ignition wire on the Amps... are just there to trigger a relay inside the amps anyway...
    you will be fine running the remote amp lead from the M2-atx to the 1st amp and from there to the 2nd amp...
    thats what I do.. except I have a Carnetix..
  1. Amp running hot...??
    By Emerica2843 in forum General Hardware Discussion
    Last Post: 02-08-2006, 05:40 PM
  2. Amp running hot...??
    By Emerica2843 in forum Car Audio
    Last Post: 01-29-2006, 07:29 PM
  3. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 06:38 PM
  4. Running remote signal to amp from parallell or serial port?
    By burnout.no in forum General Hardware Discussion
    Last Post: 01-08-2004, 03:30 AM
