Results 1 to 10 of 16
Thread: Carnitx 1900 + AOpen MiniPC- where to hook in the startup/shutdown wires?
    Feb 2004
    Milwaukee, WI
    I have a new Carnitx powersupply and the AOpen 910 mini PC. Wondering if anyone has been able to hookup the startup/shutdown leads to their machine, since it is a very small and sealed up system I was wondering what people might have done to get that aspect to work?
    Constant Bitrate godraj's Avatar
    Jan 2006
    east coast NY
    Don't know about the AOpen but basically you want to look for 2 wires that goes to the power button, just tap those two wires.
    Low Bitrate vwgtipowr's Avatar
    Jan 2006
    Bedford, NH
    Quote Originally Posted by HACKTHS
    Yes you can do this with a quick soldering job.
    I used cat5e cable I had lying around, and did this both to a laptop and desktop. The laptop is dead, so now I will be using a cheap desktop I bought. It had 4 points soldered to the board, 2 must have been ground the other 2 were for the momentary on switch.
    Works great! I suck at soldering, so if I can pull it off anyone can.
    GL. I will be doing the same for the reset button as well, I'll take some pictures when I get around to it.
    Car-PC progress meter (researching and collecting hardware)
    Registered User
    It pretty easy, all you have to do is solder some wire to the on/off swith. Here are some pics from when i did mine, I drilled a hole at the back of mine to let the wires through.
    Newbie CorsairJohn's Avatar
    Feb 2006
    San Jose, California
    The carnitix 1900 sound about right at 70 watts. Where did you find it ?
    I'm going Aopen mini PC route now too.
    Nov 2003
    Marietta, GA
    Aopen power button to P1900 connection?
    Guys...here's a picture that may be a bit clearer.
    MikeH
    Jun 2005
    awesome, thanks!!!
    Feb 2004
    Milwaukee, WI
    That pics looks different then the one Kalt did, look where the solder is- between the A and O. Mike yours is next to the A.
    Registered User
    You can use the two pins on either side, they do the same thing. Thanks for the Pic Mike.
    Feb 2004
    Milwaukee, WI
    Excellent, I don't have to rewire
