Results 1 to 10 of 10
Thread: Question on m2-atx 5v rail to power USB hub...
    Low Bitrate vwgtipowr's Avatar
    Jan 2006
    Bedford, NH
    Arrow Question on m2-atx 5v rail to power USB hub...
    I plan on using on mounting a 4 port USB hub into my dash/glovebox area.
    I will also be buying a m2-atx power supply for the car-pc I am building. I have been doing extensive research over the last few weeks.
    One question I cannot find an answer to is:
    Since I am planning on having the powered hub in the dash, and mounting the PC in the trunck (with the power supply) is it feasibly to run the 5v power from the power supply to the hub (prob close to 15', at least 10' once the wires are routed out of site). Will I see dramatic power drop off over that distance?
    The hubs I have been looking at are 5v 2.6-3amp.
    I would also have to do the same to run the touch screen most likely.
    I am still in the planning/research stages, but if someone could help out here that would be great. I have picked through the search for a while and came up with nothing useful.
    Yes, I'm a newbie to this site, so get your shots in if you want.
    Edit: Here is some more info on my setup (so far)
    P3 500Mhz
    256MB RAM (2x128MB modules)
    Ausus MB w/On board sound/lan/video
    40GB 5400 2.5" laptop drive
    Floppy drive (getting removed)
    CDrom (getting removed most likely)
    Maybe 1 or 2 PCI cards.
    The power supply should be more than enough on the 12v Rail, it is the 5v rail that might not be enough since I will be running numerous USB devices (laptop drive, LCD touchscreen, HUB, phone data cable for internet/charge, DVD-rom drive, and maybe USB fm tuner).
    Car-PC progress meter (researching and collecting hardware)
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    just make sure the wires you are running are thick enough to handle the load...
    Jan 2006
    Bedford, NH
    Quote Originally Posted by strohj
    Is there any basic rule of thumb on calculating resistance over distance to determine what guage wire to use?
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by vwgtipowr
    Ya, there is.
    FAQ: Connecting your Car PC's Power and Speakers
    Why am I being nice, can someone please tell me.
    Michael
    Oh, BTW, it is in the FAQ section.
    Jan 2006
    Bedford, NH
    Quote Originally Posted by Wiredwrx
    Michael
    Because you are a nice guy.
    My searches didn't turn anything up, I must have used the wrong key words.
    I would post the chart here, but it is in HTML format.
    Distances are quite a bit longer than I expected.
    Constant Bitrate 01black_ac's Avatar
    Jul 2005
    NJ
    You might find this of interest. I've been considering this USB hub for my own dashboard mount. It's nice and tiny, and you can see the spec-listing on the side shows it only draws 2.1Amps on the 5v rail. Plus, for a limited time it's only $10.
    http://www.compusa.com/products/prod...ct_code=310730
    '01
    [edited to clean up the link]
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
    Aug 2004
    Pearland
    hmmm interesting...
    Jul 2005
    NJ
    <offtopic>
    strohj, how do you like the Rikaline 6010 GPS? I've used mine for a while with a laptop, and I think it's pretty good, especially considering I got it for only about $30 on ebay. I've been using mine with MS Streets/Trips '05, but not sure what GPS app I'll use in the car system though.
    Have you tried mounting the 6010 under the rear shelf of the car (in the trunk), between the rear speakers? I think I want to keep my GPS located in the rear of the car, since it will be much easier to swap it out for a new model somewhere down the line, but I'm wondering how responsive a GPS of this type is if it doesn't have direct sight to the sky...
    </offtopic>
    '01
    Aug 2004
    Pearland
    I love it.. its very accurate.. and fast to grab onto the satellites...
    I use mapmonkey for navigation in my truck... oh and I have it mounted underneath the dash in the front.. I get anywhere from 6-12 satellites at all times
    Constant Bitrate RawsonDR's Avatar
    Dec 2005
    Dayton, OH
    Quote Originally Posted by 01black_ac
    USB is spec'd at 500mA. 4x500mA = 2amps, so that explains the power rating. It's not going to draw nearly anything on its own - it's just a worst case number. I don't think extraneous power draw would be an issue for any USB hub.
  1. ATX power supply question
    By dudah85 in forum Power Supplies
    Last Post: 10-10-2006, 04:49 PM
  2. Replies: 6
    Last Post: 12-27-2005, 01:41 AM
  3. Help with USB Hub power issue
    By millc5 in forum Power Supplies
    Last Post: 11-21-2005, 05:04 PM
  4. Is DC powered USB hub good idea?
    By civic5zigen in forum Power Supplies
    Last Post: 10-21-2005, 05:29 PM
  5. Laptops, Standby and USB Power Idea
    By matthewtoney in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-17-2005, 10:38 PM
