Results 1 to 3 of 3
Thread: Help on Carnetix Voltage Detect
    Banned RPM_VR4's Avatar
    Nov 2004
    My Carnetix 60w v1.5 turns off if the voltage drops below 12.1V. It is supposed to be 10V, but it's not, it is 12.1V. Because of this, I can not run my PC without my car started .
    Does anyone know which resistor devider to change?
    I did and , but all I found was a thread on the Carnetix forum saying that people on MP3Car were changing it from 10V to 11V. However, the search on MP3Car returned no such results.
    Again, what I need to do is change mine from 12.1V to 11V low-battery cut-off.
    Constant Bitrate UnsanePyro's Avatar
    May 2005
    Ah ****, I don't have my stuff right now cause my car was in an accident, but is there possibly a jumper that does it? I remember there being a few in there, but they may control only different times...
    :: '97 2.5 TL :: CarPC 1.0: Complete :: CarPC 2.0: 95% ::
    Nov 2004
    No, there is no jumper for voltage detect. From what I have read, it is done with the combination of a resister voltage divider, and firmware code (not sure if it is read through a ADC or what).
    I just need to know which resistor to change, I can figure out what to change it to myself. Actually, all I need is a schematic and I could figure it all out from there.
    I also have no idea what my 60-watt v1.5 thinks the battery is too low at 12.1 volts. I'm fairly sure it was designed to cut-off at 11V. ???
  1. Options for Newbies for powering CarPC...
    By RoyN in forum Power Supplies
    Last Post: 04-23-2005, 05:00 PM
  2. Need help understanding efficiency and voltage regulation
    By sansoo24 in forum Power Supplies
    Last Post: 04-22-2005, 03:45 AM
  3. Replies: 7
    Last Post: 01-14-2005, 11:56 AM
  4. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 07:09 AM
  5. DC-DC psu and high capacity HDD
    By GrahamS in forum General Hardware Discussion
    Last Post: 12-19-1999, 06:44 PM
