Results 1 to 10 of 12
Thread: what is hard off?
    Dec 2005
    Killeen, Tx ( Iraq)
    what is hard off?
    like the title says what is it? i have a m1 atx and i want to set it to 30 mins before shut down. i dont understand what the hard off feature is and how to enable or disable it. thanks
    Elsewhere
    Hard off is when the power supply cuts all power output.
    How about the Wiki?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Hardoff is the term use for the manufactures to describe a brute power off (meaning that if for some reason the OS hangs, the PSU will power off the SYS even if there is an APP open *same action than when you keep the power button press for 5 secs or more*)
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    The opposite of a hard on, like when you see this girl
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    Quote Originally Posted by selmerguy
    what is hard off?
    its when your not horny anymore
    i got dat ***** sittin on 22s! SUPERMAN EDITION!
    Jan 2005
    Chicago, IL
    i always thought that softoff= software power down and hardoff =hardware power down
    Dec 2005
    Killeen, Tx ( Iraq)
    ok so when i put the jumpers in the 30 min selection it WILL power down in 30 mins right?
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    Does anyone know why hardoff is still recommended over the 11.5v cutoff? It doesn't seem clear as to why it would be required to use the hardoff function to prevent battery drainage when the PS is supposed to cut power anyway.
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Quote Originally Posted by silencery
    it is an extra safety feature, incase:
    your operating system hangs during shutdown (softoff) and so your computer is still running
    OR
    your battery voltage goes under a certain level (which will make it incapable of starting your car engine)
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
    Poet Laureate rustyboxx's Avatar
    Feb 2005
    The Côte d'Azur of England - Hot totty central
    Quote Originally Posted by Pudge
    Lgbr ain't gonna be pleased you posted a pic of his girlfriend
    Only true postwhores remember everything they post
    REP CLUB IS DEAD
    LONG LIVE REP CLUB
  1. Ethics and hard drives
    By Chairboy in forum Off Topic
    Last Post: 01-05-2005, 12:21 AM
  2. Hard Drive not the usual
    By saintx in forum General Hardware Discussion
    Last Post: 11-06-2004, 05:00 PM
  3. Vibration-proof Hard Drive mounting
    By Flash_xx in forum Fabrication
    Last Post: 10-14-2004, 03:25 AM
  4. load soft ware to usb hard disk then load to comp
    By tracker92 in forum General Hardware Discussion
    Last Post: 08-29-2004, 07:57 PM
  5. zootjeff's DC to DC power supply and hard drives
    By Squeezer in forum Power Supplies
    Last Post: 11-05-2002, 09:50 PM
