Results 1 to 6 of 6
Thread: m2-atx problem
    Feb 2006
    m2-atx problem
    I found some other people on here with the same problem but did not really find a solution to it.
    I just got an m2-atx power supply, and when I try to turn it on (either using the ignition or using an external power switch), my system turns on for about 1 second (fans start up briefly, video flashes) and then shuts down.
    Here is the system:
    80GB ide hard drive
    usb gps device
    512MB ram
    althlon xp 2200+
    radeon 9600 video card
    I believe that the power supply is big enough to power this (it is 160W and my stuff should use under 100W I think), but is it possible that the video card uses too much power? I'll gladly buy a new motherboard with onbaord video if that's the problem, but I was trying to get away with using old hardware.
    Any other suggestions?
    Low Bitrate grimor2000's Avatar
    Dec 2005
    Chicago-ish
    try a different power supply (a normal PSU would work) if it does then you know it involves your m2-atx. I wouldn't think it would be drawing too much power that soon in the startup. I know a house PSU will send a small surge of power out, then of it doesn't see the computer attatched it will kill the power fairly quick. this can cause the symptoms you said.
    Causa latet vis est notissima
    VIA SP13000
    1GB DDR400
    Slimline Slot-load DVD-RW
    60GB 2.5 Inch SATA 5400RPM
    Dual Active PCI riser
    PCI TV/FM card
    Logisys FP800
    Thermaltake VFD Media Lab
    M1-ATX
    Feb 2006
    It works fine in with a normal psu. I was running it with an inverter before. I was hoping it was something I did wrong. it's such a pain to send stuff back.
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by redled
    Video cards are notorius for sapping lots of power. Try removing the video card and either use the on board, or a much more basic card. If you must, buy the cheapest video card you can and try that.
    You really should check the FAQ section becuase power requirements of a system have very little to do with TOTAL WATTAGE, but wattage per voltage rail. The M2 will NEVER be as powerfull as most "regular" desktop ac-dc PS since they produce 15 amps on the 12 volts, 25 amps on the 5 volt rail. Your system probably was under those levels, but it is possible they are exceeding the M2 ratings.
    You should check the FAQ (and search for wattage calculator) and run it for your system, and check the wattage per rail. If you look for a post I made in the FAQs, I have a link to a calculator that breaks out the wattage per rail.
    Michael
    Low Bitrate Linde's Avatar
    Jan 2006
    Sweden
    I have sent my m2-atx back to provider. Will get a new working back I hope. :/
    // Daniel
    Variable Bitrate DaveB's Avatar
    Mar 2004
    Mine is doing the same thing. Powers up for a second or two and then shuts down. Is this a bad M2-ATX?
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
  1. Xenarc Problem or Polarity Problem?
    By mbkowns in forum LCD/Display
    Last Post: 01-06-2007, 09:57 PM
  2. Combining two ATX cables
    By LockNTross in forum Power Supplies
    Last Post: 09-22-2006, 08:51 PM
  3. PW-120-M Problem
    By Shmeker in forum Power Supplies
    Last Post: 07-11-2004, 11:06 AM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  5. Interesting problem trying to extend ATX switch
    By InFix in forum General Hardware Discussion
    Last Post: 12-21-2002, 03:52 PM
