Yes, you need the P4 connecter. There are adapter cables. Cost under $10.
I have an M896F motherboard and an M2-ATX power supply. The motherboard has a 20 pin ATX power connector as does the M2. The motherboard also has a 4-pin power connector which is apparently used with the P4 processors. I have a pentium M processor.
When I turn on the power the fan runs for about 30 seconds and then everything shuts off.
Am I supposed to hook up the 4-pin power connector between the M2 and the motherboard?
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
try it and see if it works
i got dat ***** sittin on 22s! SUPERMAN EDITION!
