Results 1 to 10 of 11
Thread: Can I power an Opus 120 at home with a 10 Amp Regulated Power Supply?
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    If it was a perfect world, the opus would draw a maximum of 10A. 120W = 12V X 10A. But in the real world, you would probably be pushing the limits of the 10A supply if the opus is fully loaded. Unless it is fully loaded, it should work ok.
    I found that the best way of supplying power to the opus in the house is to use an old car battery .
    Aug 2005
    Near Buffalo, NY
    Save the cash and just buy a cheap 300watt atx psu. And mod it to run without a motherboard. (greenwire to any black)
    Dec 2003
    New Jersey
    Well I already have this power supply. Will it draw more than 10A if I'm just running a 2.5" HD, PCMCIA wifi, and PCI card?
    Rich
    VCS
    VCS is offline
    Apr 2005
    AZ
    You running a MII 12000, right? Unless the PCI card is a big graphics card, 10 amps should be plenty.
    Jan 2006
    My draw with opus 120 is 2.8A when playing music with DVD player and surfing the net using SMC 108mbit wireless USB + DFI G5M100, Pentium-M 1.8Ghz, 2 x 512 MB RAM, 80GB 2,5", Slim DVD+/- writer, Cinergy 600 PCI (radio on), + 3 fans.
    It is steady at 2.8A, some peaks at 3.2A.
    Indash 7" / Travla C138 / Opus 120 / DFI G5M100 / Pentium-M 1.8Ghz / 1 GB RAM / 80GB 2,5" /
    Slim DVD+/- writer / Garmin OEM15L-W GPS / Audigy2 NX / Cinergy 600 / SMC 108Mbps
    Dec 2003
    New Jersey
    Quote Originally Posted by VCS
    yes
    Quote Originally Posted by backspace
    Thank you both for posting. Seems to be running fine so far.
    (I gotta get one with meters)
    Rich
    VCS
    VCS is offline
    Apr 2005
    AZ
    Quote Originally Posted by srcstc
    Thank you both for posting. (I gotta get one with meters)
    You're welcome, of course. If you really don't need an adjustable, lab power supply, you can run to your local radio shack get something like this to measure the current: http://www.radioshack.com/product/in...ductId=2103176
    Admin
    Aug 2005
    Dude, you've got a meter to tell you what the Opus is drawing. Unless that meter pegs to the end of the scale, you've got nothing to worry about.
    And if you *do* wind up with a configuration where the Opus is pushing 10A, you can always up the voltage to 15V. The Opus won't have any problem with this, and if anything it should run more efficiently.
    -g.
    VCS
    VCS is offline
    Apr 2005
    AZ
    Quote Originally Posted by gnomad
    Backspace does, but the original poster does not.
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. PC Power Supply and Car Amp
    By GezusK in forum Car Audio
    Last Post: 05-10-2006, 01:31 AM
  3. FS (UK) Lilliput 7.2 screen & Opus 150W Power Supply
    By StuBFrost in forum Classified Archive
    Last Post: 06-21-2004, 11:28 AM
  4. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  5. Fs Opus 150 Power Supply
    By vp911 in forum Classified Archive
    Last Post: 06-07-2004, 06:05 PM
