Results 1 to 9 of 9
Thread: DSATX no LED, no power up
    Jan 2005
    San Diego, CA
    Hey,
    I just hooked everything up for the first time following the instructions... but when i turn the switch for my igniation, nothing happens, no boot, no led...
    Can anyone help me with this? Maybe some steps to try and troubleshoot?
    Thanks in advance!
    Jan 2005
    San Diego, CA
    Also, so you know, I dont have as serial cable... So if there is anyway to troubleshoot this w/o that cable?
    I completly rewired my car for this... used to be using an inverter...
    I should have tested this before I rewired, but I didnt... so now im stuck with no comp in my car until i figure this out =/
    Jan 2005
    San Diego, CA
    bump - hopeing someone will read this monday who can help =/
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Have you checked your lines? are you getting 12v to the input? 12v on the ACC line?
    肚子笑痛了
    S60 Install
    Jan 2005
    San Diego, CA
    Im pretty sure it does, I tested the wires on my inverter, and the ACC wire on my amp and they all work..
    Only thing is, the + from the battery is heavy gauge wire, but the - going from the battery isnt, could that limit the amount of power going to this board, making it not work?
    Jan 2005
    San Diego, CA
    ok, just went out and bought a higher gauge wire and tested this... still nothing
    Jan 2005
    San Diego, CA
    Ok figured it out... it was my ACC line
    I was using the remote wire from my deck to trigger the power, I guess its enough juice to run an amp, but not enough to run this board...
    Just need to figure out where to tap into my car to get enough juice for the ACC now =P
    Apr 2001
    Portland OR
    Quote Originally Posted by solodesignz
    It is 247k ohms input impedance! It doesn't get much lower power than that! You need to be giving it at least 8 volts though at the ACC line
    -Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    um, what head unit do you have?
    my remote turns on 2 amps(200w for rear deck, 2400 for subs) and the dsatx controller
    maybee u can use a relay.
    you may want to check connections at your amp's remote to wear you had the dsatx connected, might not have had something crimmped tight, or a screw all the way tight. also check the remote wire on back of your head unit(usualy blue)
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
  1. DSATX Power Supply on LV-673 MoBo
    By Caelric in forum Power Supplies
    Last Post: 12-17-2007, 04:21 PM
  2. Power led on xenarc - necessary?
    By Barren in forum LCD/Display
    Last Post: 08-12-2005, 12:34 AM
  3. Darn ITPS! Need power help!
    By DJ-FrosT in forum Power Supplies
    Last Post: 07-16-2005, 08:40 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
