Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: M2-ATX powers all THIS!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    AMD Mobile 2800+ (havent touched the clock or voltage, currently running @ 2.13 ghz
    PC Chips M863G Motherboard
    1 GB PC3200 DDR RAM
    60 GB Laptop drive
    60 GB Full Size drive
    SB Extigy usb sound card
    Pharos 360 USB GPS
    Compex WLU11A WIFI adapter USB
    bluetooth adapter
    PS/2 Touchpad molded into cupholder cover
    PS/2 slim keyboard
    Geforce 4 mx4000 pci
    Serial port IR Receiver
    OBDII scanner from OBD Diagnostics
    Unpowered usb hub with:
    Dedicated Cell phone connected VIA usb
    USB Touchscreen
    USB Mini Keyboard
    another unpowered usb hub with two flash drives installed
    I am REALLY impressed by this. I thought i'd have to sacrifice or run my inverter powering the onboard psu for some devices. But The M2-ATX powered all these devices for over an hour connected to a 12v battery i had sitting around. Now my motherboard "says" it has something that allows usb devices to be more "efficiently" powered but who knows if thats crap or not. So maybe this will help all the people like me who wondered if the M2 was really enough
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    cheers for the info.. I ordered a M2 today, fed up of my opus 150 to be honest. It cuts out for no reason.. not often say once every couple of weeks, and its not a loose connection either. Also fed up of the drain on the battery if left in standby mode so bring on the M2. I had a M1 for a bit and was well impressed with its performance so I'm looking forward to testing this M2, like you i'm running amd set up, but mines a seperon 3000+ / 2x256 sticks of memory and at the moment just a 40gig drive. (keep killing my big ones) of course.. 1 x 7 inch xenarc, 2 x 7 inch headrest screens, a lcd 2x16, mini cdrw/dvd slot drive, 1 dlink wifi, 1 vodafone 3g card, 1 usb gps thingy, 1 x bluetooth usb thing, mini rf keyboard, usb joypad for audio stick, dlink usb radio (pile of crap) .. err think thats it, prob missed a few things lol
    Cant wait, will get it Wednesday and will install the same day and post results :-)
    CdR
    Variable Bitrate kamikaze2112's Avatar
    Feb 2005
    Barrie Ontario
    After seeing your post i am seriously considering one of these. I just wanna be sure that it's going to work for my setup:
    Via MII10000
    512 mb Ram
    40gb 2.5" HDD
    Notebook CD-RW/DVD
    USB GPS reciever
    USB Bluetooth Adapter
    PCMCIA Linksys wireless NIC
    PS2 KB/mouse
    XMD1000 XM radio tuner.
    Lilliput 7" with USB touchscreen
    I power my screen thru the cigarette lighter adaper for now, but if there's enough juice from the M2, i may power the screen from it instead.
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    the real power whore is the CPU/mobo....and the VIAs take next to nothing, you should be more then fine.
    PC Components:
    My work log
    Feb 2005
    Barrie Ontario
    sweet. what's the reliability like on these things....it can get pretty chilly outside too...
    Feb 2005
    Barrie Ontario
    also, is there any way to get the offdelay set to 30 min, and hardoff to 2hrs? I have a habit of going into stores for longer than 30 sec at a time, and don't want to keep the car running
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    fook me!
    well sonic, be carful and mak sure you have some good cooling on it. nice one.
    Woodbridge, VA
    Blog Entries
    32
    Oh i forgot the slot load dvd . Add that to the list as well. I cant wait to get this puppy runnin in the car! As for the guy with the via.. you wont have ANY problem
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I have this PS also and I like it.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
    VENDOR - ITuner/MiniBox
    Nov 2003
    -42C, still fires up.
    However, I doublt that your M/B will work at these temperatures....
    EPIA M1000 seems to handle -35C, while EPIA MII 10K is not as good (-15C or so).
    Andrei
    Quote Originally Posted by kamikaze2112
  1. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 02:14 PM
  2. Wtb: M2 Atx
    By EsKALad in forum Classified Archive
    Last Post: 01-03-2006, 09:59 AM
  3. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 09:06 PM
  4. Micro ATX or ATX
    By custardbomb in forum Power Supplies
    Last Post: 08-14-2005, 07:48 AM
  5. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 03:22 PM
