I'd also like to know.
Does anyone KNOW FOR CERTAIN if the switched ignition wire on the M2-ATX is for signaling only, and that the constant 12 volt wire actually carries all of the power?
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
Bump.
Come on guys....someone must know the answer!
I'm wiring right now and I need to know the answer to this question so that I know how many amps to plan for on the switched ignition wire. I have 10 guage from the battery for constant 12 volt. If the switched ignition is just for signaling, then it doesn't matter how big the wire for it is or how many amps it will carry. Heck, I could tie in to the lead on one of the cigarette lighters that is only hot when the key is on. But I can't do that if the M2 might take as much as 15 amps on the switched ignition lead.
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
The switched 12V wire is just a sensor. It ends up in the microcontroller, draws only 1mA.
-Andrei
Originally Posted by DaveB
