Results 1 to 3 of 3
Thread: Inverter not powering laptop
    Constant Bitrate noreason's Avatar
    Jan 2006
    Texas!
    I recently purchased a 175 watt inverter to power my laptop (roughly 90 watts) but every time i try and start my laptop it turns on for about half a second and shuts off. When this happens the green light on the laptops power supply goes dim and it makes a sound like something isnt right. This inverter should be producing enough power i use to use a 140 watt from radio shack (lost it) that worked great.
    Any ideas on what might be causing this? The green light on the inverter doesnt dim and none of the inverters alarms go off either.
    Laptop works great on ac power inside as well.
    Feb 2006
    Boulder
    Are you running the inverter from your cigarette lighter plug? You're probably running into the amperage limit of the cable running in your car up to the lighter plug.
    I ran into this same problem a couple years ago. I bought the inverter right before a road trip to Vegas. On the drive out, the inverter would beep an overload warning after about twenty minutes of using the laptop, and about a minute later it would burn through the fuse.
    Not wanting to go without my laptop on the drive back as well, we stopped at a Wal-Mart and bought an extension cable, roll of electrical tape, bag of zip-ties, and a handful of the cheapest and worst quality tools I've ever seen. We cut off the ends of the cable, bolted one end right to the battery terminals, ran it back under the hood, through the passenger side doorjam, under the dash and to the inverter. Then we returned the tools. It worked beautifully.
    Jan 2006
    Texas!
    I just returned it for a black and decker 200 watt for the same price and it works
  1. Powering my 12v laptop auto adapter with the 19v output of a p1900 = flames?
    By derbis in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-08-2005, 04:04 PM
  2. Replies: 3
    Last Post: 12-13-2004, 01:50 AM
  3. Powering Laptop with the Car Battery
    By mintee in forum Power Supplies
    Last Post: 11-29-2004, 08:38 PM
  4. what exactly do i need to use? (powering laptop)
    By chris in nh in forum Newbie
    Last Post: 06-16-2004, 06:17 AM
  5. Powering up a laptop remotely
    By dmbrown73 in forum Power Supplies
    Last Post: 03-07-2002, 08:40 AM
