Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: 30 Min Off Delay, M2-ATX?
  1. #21
    Newbie Orange Bus's Avatar
    Apr 2005
    Quote Originally Posted by Sonicxtacy02
    can anyone else confirm that... that hour option looked good to me
    I've bought a new M1ATX since that post and the 10min/ 1hour option works fine.
    Cheers
    Julian
  2. #22
    Variable Bitrate redbullah's Avatar
    Mar 2006
    Belgium
    i set mine on abcd 0101 and it works fine.
    1h delay
    1h 15m hardoff
  3. #23
    Constant Bitrate Beezer's Avatar
    Oct 2006
    Guy, you know what this is just BCD (Binary Coded Decimal) ? http://en.wikipedia.org/wiki/Binary-coded_decimal
    You can wire up a BCD switch like this http://www.maplin.co.uk/module.aspx?...17m3#more_info to make it easier to switch settings without having to fiddle about with jumpers.
  4. #24
    Constant Bitrate rxh81's Avatar
    Dec 2006
    Europe/Austria/Graz
    My prefered setting would be 5sec / 24h.
    Because I would want to be 24h in Standby and then the PS should pull the plug !!
    But unfortunately not possible . Probably I have to do my own start / stop controller, damn! Or does somebody see a solution??
  5. #25
    Nov 2010
    I went to the site mentioned here for the source code, but it was not available. Can you send me a copy of provide a working site?
    Quote Originally Posted by kamikaze2112 View Post
    Andrei from Mini-Box confirmed the existance of the
    0001 10 minutes / 1 hour
    1001 15 minutes / 2 hours
    0101 1 hour / 1 hour 15 minutes
    settings via e-mail. He also said that the source code for the unit is available for modification. I wonder what sort of work it would be to modify the code...
    Source code in zip file is available here:
    http://www.epiacenter.com/modules.ph...rticle&sid=529
  1. Powerin the LCD with the M2 atx
    By luckyno in forum LCD/Display
    Last Post: 01-20-2006, 01:14 PM
  2. Wtb: M2 Atx
    By EsKALad in forum Classified Archive
    Last Post: 01-03-2006, 08:59 AM
  3. morex 80wpsu and reg ATX cable dilema!!
    By surfy in forum Power Supplies
    Last Post: 08-16-2005, 08:06 PM
  4. CarPC shuts down after aprox. 30 min
    By Jan-Willem in forum General Hardware Discussion
    Last Post: 09-29-2004, 08:08 PM
  5. New Idea for an awesome atx shutdown
    By moahdib in forum Power Supplies
    Last Post: 07-03-2002, 11:42 AM
