That really depends a lot on the motherboard you are using. I'm running an embedded mobo which only requires +5v and +12v for example.
Rob
Rob
not essential, BUT serial ports and some onboard sound cards need -5V to function..... since you have an Irman, your gonna need it!....
unless you can use a USB ---> serial converter.... since the USB port only has 5V+ in its plug......
Project - GAME OVER :(
No, you can't do that, the input to the -5volt regulator should go to the -12volt rail..
Sorry that was a mistake. now should be ok.
Yes, that will be fine. Though I would also put a 10uF capacitor at the input of the regultor, and add a 0.1uF unit at the output. The result will be a much more stable -5V.
do you mean like this?Originally posted by Aaron Cake
sorry for my ignorance, I don't know much about electronics.
Ahh, I don't think you need the 220uF on the output..
Aaron Cake I need your confirmation...
