Sounds like you are running very close to the limit on your 12 volt rail. If your guess is off by just a couple of watts, you will be over. Consider that some of those components may draw more juice on startup and that could be the issue there.
Do you have adequate cabling in the car? 12 gauge sounds too thin to me. Most people use 6 or 4 or less for higher power setups. Remember that there is resistance over the longer lengths of wire that translate into voltage drop.
You're sure it is getting cooled adquately?
I won't bother to tell you that 3 ghz is overkill for a car PC.
LinkBack URL
About LinkBacks
. Got everything together and working, just waiting on some warm weather here in Northern PA to do the install when my system won’t boot, not even a POST or any output to VGA
. After removing everthing but the processor and cpu cooler, it still would not POST, and not even a memory error beep. I even tried resetting the bios with the
