Results 1 to 9 of 9
Thread: Help with this Power Supply!!
    Jan 2002
    Venezuela
    Question Help with this Power Supply!!
    This PS have 3 input connectors:
    model: MPD-8071-S
    DC INPUT:
    10-30V == 13A max
    DC OUTPUT:
    +5V == 10A
    +12V == 1.5A
    -12V == 0.3A
    How do I connect this in the car?
    I mean, which connectors should I use?
    Jan 2002
    Venezuela
    please help me!!
    FLAC Mastero's Avatar
    Aug 2001
    India
    hey dont cry .. mastero for ur rescue
    TB1--DC input : Terminal block.
    TB2--DC output : for the mobo etc
    TB3--for FAN use only .
    ok now the Tb1 has three connectors
    OV= ground
    +15= positive
    E = earthing or ground
    i hope this is clear in other words just connect the +12 of the car to the +15 and the ground to the 0v & E
    Hope this helps u
    Mastero
    Jan 2002
    Venezuela
    I'm powering this PS with a normal AC-DC PS to test it. with the +12@9A output.
    I did what you told me. It doesn't work. when I connect it, the AC-DC Power supply shut down.
    please HELP!!!!
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    i think you are pushing too much current. the webpage lists the input at 3a@10V max. it has a peak current capacity of 15A @ 10V. i think you are overloading the converter. i also think the OV might be something to do with the overvoltage protection circuit that is built into this converter.
    i could just be talking nonsense, since im pretty far from an electronics whiz.
    i would try 12v to the 15v pin
    and ground the E pin.
    leaving the OV pin open.
    but i would also have a fire extinguisher near by!!!
    thinking back to basic electronics i took in college, couldnt you bypass some of the current around the dc-dc by shorting the 15v and E pins with a resistor. hmm, BETTER NOT TRY THAT without someone elses advice.
    anyway, this was pretty much pointless. hope you figure it out.
    ~Mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
    Jan 2002
    Venezuela
    Originally posted by mp3z24
    i
    I already did that and nothing.
    Apr 2001
    Chicago Suburbs
    alright, i thought about it a little more and i think the 0V is an overvoltage dump.... if there it too much power flowing into the dc-dc and it trips, the power has to go somewhere... wouldnt ground be the best option. would this make your ac-dc trip also, i dont know. i still stand by my guess that you are pushing too much current into the dc-dc. i bet if u can drop the current down to a couple amps, then it might work.
    ~mike
    Jan 2002
    Venezuela
    Now its working. I change the ac-dc PS and works fine.
    Now I just need to get the -5V.
    Thanks for your help.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    You don't push current into something, something draws current. The current drawn depends on the voltage you feed it and the effective resistance of the device.
    Some (most??) PC power supplies require reasonably balanced loads on their outputs, with the expectation that the heaviest load will be on the 5v line (check the current ratings on the power supply, chances are that the 5v line is well above the 12v line).
    Given that most PC SMPSUs run with a single switching transfomer for all the voltages (with different tappings to get you different volatges), when you draw that much current on the 12v line (especially the surge current at startup), the trip is likely to kick on the overvoltage protection on the 5v output of the PC power supply.
    That would be my guess.
    Rob
