+ Reply to Thread
Results 1 to 10 of 15
Thread: Technical explanation of inverter noise?
    Newbie FoRNiK8ToR's Avatar
    Mar 2005
    CA
    I’ve seen plenty of threads saying that inverters will add noise to your system and DC-DC is better, yadda yadda yadda. But I was just curious as to how exactly using an inverter induces noise into your speakers? Technically, how does the noise manifest itself into the speakers? People recommend a pure sine wave over a modified one as a way of eliminating that noise… I don’t technically see how that would help? I’m not saying that I don’t believe it, but I just don’t understand how modified sine waves powering the system would manifest their inaccuracies in the speaker outputs whereas a true sine wave inverter wouldn’t?
    It looks like of the few here that have chosen inverters over DC-DC, it’s seemingly random as to whether or not they’ll experience the added noise in their system. So I was just wondering if it is truly “random” or if it’s a function of proper grounding, proximity to other electronics, etc? maybe all of the above?
    Variable Bitrate numbers's Avatar
    May 2005
    Inverters tend to raise the chance of having a noisy system because of the fact that they put high voltage ac in close proximity to everything. The actual way that the noise gets to the speakers is that electromagnetic interference is radiated from the ac devices and wires and somehow finds it's way to audio wires. If the audio wires are too close, or if they have ****ty shielding, or if they are improperly grounded, they are more likely to pick up that interference and carry it to the speakers. Dc-dc setups also produce emi, but it is a fact that there will be more emi present around an inverter setup than a dc-dc setup. What it all comes down to is just how much of that emi is finding it's way into your audio cables.
    Folks who say pure sine wave inverters are better for carpcs are saying that because they saw that someone else said it. That someone said it because he heard someone else say it.... I don't know exactly who first said it, but they're not entirely right.
    Folks who blame their noisy setup on their inverter need to learn a bit more in the area of keeping emi out of their audio cables.
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Quote Originally Posted by numbers
    umm, I don't know about all of that.
    Pure sine wave inverters produce clean, steady, reliable ac current, comparable to the mains going to your house.
    The noise everyone talks about is due to the lesser quality modified sine wave inverters being cheap and not producing a clean current.
    True, the location of the ac wires will have some effect, but the majority of the nosie is due to the inverter itself.
    reference:
    http://www.donrowe.com/inverters/inv....html#modified
    May 2005
    Most here do not. That is why I posted.
    Clean, steady, and reliable are three things that have absolutely nothing to do with the difference between a modified and true sine wave. Try to find a reference that wasn't written by someone who has something to sell you.
    The noise that everyone talks about is due to lesser quality audio installation jobs using crappy cables and poor routing technique. A modified sine wave is in no way of lesser quality or any less clean. It is just a different type of wave. That is all.
    The suggestion that noise travels through the power cable, through the psu, through the motherboard, through the sound card, and through the speaker wires to produce noise in the speakers is nonsense and reveals a severe lack of fundamental knowledge by the suggester concerning such things as sine waves, inductance, emi, switching power supplies, and just alternating current in general.
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    In clarification of the above, isn't it something to do with the high frequency switching which inverters do to jump the voltage up? And why don't the inverters for LCD backlights have the same effect (in general)?
    May 2005
    Yes.
    They do, but the frequency is much much higher, severely reducing the noise effect.
    Mar 2002
    Tucson
    Actually, a modified sinewave inverter puts out something more like a square wave. A square wave contains a base frequency of 60 Hz and multiple odd harmonics. It' these harmonics that cause problems because they extend well into the audio frequecy range, and show up as noise on any unsheilded audio cable or trace. They can also ride on the computer's powersupply lines because the filtering is not designed to handle signals in this range. As mentioned above, good single point grounding and audio sheilding can elimate a lot of problems. Most DC to DC converters operate at 250 Khz or above so any noise that does radiate is too high in frequency to be picked up and broadcast by your soundcard and amplifiers.
    That's my 2¢ on the subject anyway
    Walt
    Feb 2006
    Quote Originally Posted by waltsongs
    Besides. 50Khz is above human hearing. Maybe a dog could hear it.
    May 2005
    A modified sine wave will produce more interference than a true sine wave, but that does not make it any less clean or reliable. The practice of keeping that interference out of your audio is the same as always. It isn't that complicated.
    Low Bitrate silveralt's Avatar
    Dec 2005
    I had a modified sine inverter hooked up to my cig lighter and had interference when my car was wet. I hard wired it to the battery and had no problems and still have no problems ever. I think it is a grounding issue with it.
+ Reply to Thread
  1. Unusual inverter noise problem
    By launter in forum Power Supplies
    Last Post: 10-21-2005, 10:05 AM
  2. Shielding TV signal from inverter noise
    By Orion in forum RR Bug Tracker
    Last Post: 05-01-2005, 04:51 AM
  3. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  4. Inverter, Cigarette lighter, noise, Resolved?
    By Spec-pc in forum Power Supplies
    Last Post: 04-02-2004, 04:09 PM
  5. Inverter Noise
    By Cherub211 in forum Power Supplies
    Last Post: 02-20-2004, 01:09 PM
