Results 1 to 10 of 10
Thread: How do I get 15V or 18V from 12V??
    Jan 2002
    Venezuela
    How do I get 15V or 18V?
    I need this becouse I think my DC-DC PS doesn't work with 12V
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    You could use a switch mode power supply to setp up the voltage.
    There is no combination of passive components which is going to give you what you want.
    Rob
    Jan 2002
    Venezuela
    Rob
    what is switch mode power supply????
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    More complicated that it's worth. It'll be cheaper just to buy or build the proper DC-DC power supply.
    Jan 2002
    Venezuela
    can I use a car DC converter for a laptop? what do you think?
    Jul 2001
    what are you trying to power up ? more than likely you can feed it directly off your car and it will be fine - it just depends on what you are trying to power
    Jan 2002
    Venezuela
    There most be a solution, please help!
    Jul 2001
    Apr 2000
    Bedfordshire, UK
    I did the hard work (!!!???) for you, took me 30 seconds to find this with Altavista:
    http://www.ee.uts.edu.au/~venkat/pe_html/pe07_nc8.htm
    Rob
    Jan 2002
    Venezuela
    Forget about the problem, it works now.
    thank you anyway
