Results 1 to 10 of 10
Thread: Is my M1-ATX being overworked?
    Maximum Bitrate Snootch's Avatar
    Sep 2003
    Tampa, Florida
    First off, see this thread.
    I believe the problem is power related as I don't have any problems detecting the hard drive when powered by a desktop PSU. Are the large 3.5" desktop drives that power hungry? Here is a list of devices running off the power supply:
    VIA SP-13000 1.3ghz Motherboard
    8" Lilliput
    Audigy 4 PCI card
    Seagate 300gb 3.5" HDD
    USB Devices:
    Powermate
    Bu-353 GPS mouse
    touchscreen
    Do I need to upgrade to the M2-ATX? Or does something seem amiss?
    WORKLOG
    Asus P5N73-AN Mobo/Celeron E1400 2Ghz Dual Core CPU/2Gb GEIL PC3200/120GB HDD/DSATX PS/8" Phylon TS
    Webpage
    Sep 2003
    Tampa, Florida
    Just found the EpiaCenter calculator, and with 3 USB devices, the HDD, and one TV card (for the PCI sound card), the total power used comes to 78.13 watts at DVD playback loads. Add the 7 watts that my Lilliput draws, and that makes the total 85.13 watts. I'm sure at start-up there is just as much power being drawn if not more than when video is being played. I think that this is probably my problem. Anyone want to buy an M1-ATX?
    WORKLOG
    Webpage
    Variable Bitrate 12Vsystems's Avatar
    Mar 2005
    Orange County, CA
    The 12v rail is limited to I think to 2 amps. The 12v from the 3.5" drive makes me think it might be overloaded.
    If so the M2-ATX will solve you problem
    Spent all my money on carputers now I have to work a real job.
    http://www.858graphics.com
    Mar 2005
    Orange County, CA
    save the M1 you will find a use for in the future
    it will make a good voltage regulator for a 15" screen or you could make a relay setup using the ps-on fuction.
    Dec 2005
    Man! That calculator is great!
    May 2005
    San Clemente, CA
    Quote Originally Posted by Snootch
    Cool idea, but that calc is missing some major power drainers like the motherboard and memory, which is at least another 50 or so watts. It's also missing soundcard, although the TV tuner looks like a decent sub. The power draw is also on the way low side and he is not adding any safety zone. The breakdown he has is very good, though and easy to use - I wish there was a modern one that easily did it.
    There are also good:
    http://forums.extremeoverclocking.co...43&postcount=1
    I like mnemonik's, but the JS one gives you a breakdown of each component. I still use 8w per 128MB, like one mentioned in the past. I think it's more realistic.
    Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D P8700 / MB: Jetway NC64-LF / SC: ASUS Xonar Essence STX / RAM: Crucial 2x1GB 1066MHz / HD: MTRON 2.5" 30GB / DVD: Panasonic UJ-815B / PSU: Opus 180w / LCD: Xenarc 700TSV
    Aug 2005
    N Wales
    you choose the motherboard at the top, and i'm sure they've included power for the motherboard in their calculations as well as a stick of RAM and the onboard cpu and onboard sound.
    Snootch - I am running a MII12000, 200 GB 3.5" Seagate baracuda plus, 8" touchscreen, usb gps, usb mouse, usb slimline slot load dvd & cd-rw, and sometimes i have a few extra usb devices plugged in (usb sound card, all in wonder remote, d-link radio) and i have had no power issues, all with a m1-atx. Not exactly the same spec, but similar. The hard drive is definately the most power hungry device, not sure there will be too much difference between a 200 and a 300 gb device tho.
    Hardware: MII12000/512MB RAM/250GB HDD/8" touchscreen/slot load dvd/M1-ATX, 802.11g/bluetooth
    Software: Road Runner, Map Monkey
    Working on: reliablility!
    May 2005
    San Clemente, CA
    Quote Originally Posted by RichEO
    Not possible they included RAM usage, because the power varies depending on the size and it should be far more than that. They did include mobo usage, my bad, but the EPIA calc is still severely "generous." 2.5w per USB device? 4.9w for a TV tuner? Don't rely on that one.
    Sep 2003
    Tampa, Florida
    I am running 512Mb of RAM , and am using an un-powered USB hub though, I don't know if that makes much of a difference. I have confirmed that it is a power problem at startup... If I get stuck on "Detecting IDE drives", I can shut the computer off, pop the fuse out of thr Lilliput "egg", restart it, and plug the fuse back in after about 10 seconds. The screen comes on, and it detects the drives with no problem. So this leads me to believe the problem stems from the M1-ATX being unable to provide everything (especially the HDD) with the necessary current at start-up.
    WORKLOG
    Webpage
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by WiCKeD 5.9L
    generous in what way? 2.5W is the most any usb powered device can draw. (500mA @ 5V). some devices such as drives will use this on startup so it is best to assume the worst case.
  1. M1 ATX Remote voltage
    By thenick100 in forum Power Supplies
    Last Post: 01-18-2006, 08:59 AM
  2. M1 ATX + Centrino 1.5 Ghz + AOPEN XC CUBE MZ855
    By luckyno in forum Power Supplies
    Last Post: 01-06-2006, 09:19 AM
  3. Does m1 atx have to be connected to mb
    By Silver Wing in forum Power Supplies
    Last Post: 12-08-2005, 07:15 AM
  4. m1 atx
    By corsab in forum Power Supplies
    Last Post: 08-21-2005, 08:03 PM
  5. Wanted. M1 ATX Lead..
    By CdRsKuLL in forum Classified Archive
    Last Post: 08-12-2005, 09:57 PM
