Results 1 to 3 of 3
Thread: Ground Loop Isolate - Good Results!
    Nov 2004
    My cpu system is a Gigabyte MATX board running a Sempron 2600+, 512mb ram, Lilli 629 molded into my dash, 220watt atx PSU, and a 700 watt (400rms) Vector Inverter with the Mpegbox Startup/Shutdown controller. I am using onboard sound/video from the mobo. I am totally headunitless now, going from the CarPC to my amps to my speakers/subs. I had initially been getting a fairly bad hiss (especially from the subs), which I suspected was a ground loop.
    So I bought the ground loop isolator from Radioshack for 15.99. It solved about 95% of my sound hissing/popping. The subs have absolutely no hiss/buzz at all anymore, and the front componets have only a tiny bit at high levels. Just wanted to put it up here that this thing, in some cases, actually works and makes a dramatic difference. I think I'll be holding off on buying an M2-ATX now until they get all the bugs out of it.
    Low Bitrate PCModifiers's Avatar
    Dec 2005
    I will keep that info in mind when I go to install my setup. Thanks for the great info!
    I love what Radio Shack puts in the description of the item: Be the only one humming to the music.
    Constant Bitrate Perrosky's Avatar
    Feb 2006
    NJ
    Ok.
    Well I'm looking for a lower configuration that the one that I use to have
    something like an amd athlon xp 1900+ that cpu does not draw more than 55w at max. but I can't find that procesor on the internet .
    anyone got a place where I can find it? or another idea o configuration??
    if some one wants to talk to me by msn messenger here is my addres
    p-santiagojr@hotmail.com
    thanks
  1. ground loop isolators work!
    By nealric in forum Car Audio
    Last Post: 02-23-2006, 08:40 PM
  2. Finding good ground to prevent Ground Loop
    By lookinco in forum Power Supplies
    Last Post: 11-04-2004, 02:23 PM
  3. Learn and fix ground loop noise
    By 14.4vTech in forum Car Audio
    Last Post: 07-03-2004, 09:55 PM
  4. Question: Arise psu: ground, neg, and pos.....?
    By Tony S in forum Power Supplies
    Last Post: 05-02-2001, 08:54 AM
  5. Alpine / PC Challenges all around...
    By acitrano in forum General Hardware Discussion
    Last Post: 11-10-2000, 08:45 AM
