Please explain why.... Your computer PS should be able to supply the current easily.... But, no, connecting 2 supplies like that would not work..
Im using and old Power supply to test my DC-DC PS, but when I connect it to the mobo, the old PS shut down.
Can I use 2 AC-DC PS in paralel or something like that, to test the DC-DC PS?
something like this:
hey Mp3 kid give me one reason why it wont work ... its like adding two AA battery .. in parallel .. so why wont it work .. hey buddy try it i think it should work .. !
but you will only know if you try so give it a try keep a 5amps fuse in between the 12voltline
Mastero
Well, I suppose it might work, but it is a bit risky, Why don't you just try it?? How much current do you need?? If all you want to use it for is 12volts, then you could rewind the transformer, and replage the inductors to get more current...
A desktop supply (well the AT one i have in front of me) outputs 8A @12v. I believe that some DC-DC supplies have 10-15A peak ratings, especially at boot up, trying to spinup the hdd and so forth.
Isn't that as obvious as a racing dogs .....Please explain why....
I'm no electronic engineer, but i cant see why it wouldn't work, maybe throw in a few high current diodes to be on the safe side, and a fuse or two![]()
http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
Australian mp3car Portal
mp3car related links Check them out / Add some
mp3car FAQ - RTFF
[########==]80% Assembling
-=Current Progress: Working Sproggy supply, building box.=-
For a simple experiment, paralleling two supplies would work. But I wouldn't leave them like that for any length of time.
