Results 1 to 10 of 14
Thread: opus problem
    eon
    eon is offline
    Jul 2005
    opus problem
    i have a problem i connected my opus to my pc and it turns on for about 1-2 seconds then turns off and the green led flashes 3 times its a 1.8 p4 and all it has connected is the hard drive and i also tried it on a 900mhz celeron and samething happened its powered by a 12v adapter in my house, any idea what the problem could be?
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    From the Opus manual
    3 Flashes : Power supply output voltages are out of normal voltage range.
    Reasons:
    1. Power supply output is over loaded or shorted.
    2. Faulty DC-DC power supply.
    eon
    eon is offline
    Jul 2005
    i need a little more help than that
    Variable Bitrate Freelander's Avatar
    Jul 2005
    NYC
    that's pretty good help by meddler. however, i guess i need to break it down. assuming the power supply is not overloaded, and the opus works is not faulty, then there is only one other option. you might have run the wires incorrectly, maybe a short. have you checked the wires?
    Elsewhere
    What more help do you need?!?!?!
    He gave you the text straight from the manual that tells you what your problem is. You're either overloading the output or your PSU is faulty.
    Look at the setup you're running. Unless you're using a low-wattage P4 1.8, you're drawing way more load than the Opus can provide.
    How do I know?
    I read this: FAQ: Will <insert PSU model> Power Supply work with my system?
    How about the Wiki?
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    i've been running a 2.4 p4 on my 150W opus for 2 years now. no problems so far. probably a faulty opus. just contact opus...they're pretty easy to work with.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
    Variable Bitrate rcdash's Avatar
    Dec 2004
    I run a 2.4 Ghz Northwood P4 - no problems (MB870 board). It lists the power consumption with my configuration and it is within spec for the OPUS.
    Apr 2005
    Queens, New York
    WHy dont you disconnect all exterl power from the PC except jsut have you power to the opus and the screen connected and see what happens. That happened to me, i got 3 flashes after it shutdown after a couple seconds. Found out i had too much stuff drawing power from my opus.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    eon
    eon is offline
    Jul 2005
    the only thing thats running is a the mobo and i just plugged it into a 900hmz celeron and samthing is happening
    Jul 2005
    NYC
    I think we aren't helping him enough. Does anyone live close to him that can swing by after work and finish his install?
  1. oh for gods sake help me, OPUS problem
    By revlis240 in forum Power Supplies
    Last Post: 11-15-2007, 04:48 PM
  2. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 12:38 PM
  3. Opus power up problem
    By baef in forum Power Supplies
    Last Post: 10-23-2005, 07:00 AM
  4. Opus 150 problem (overloading rails)
    By Craig W in forum Power Supplies
    Last Post: 07-18-2005, 11:16 AM
  5. OPUS 150 Problem FIX
    By titaniumkingpin in forum Power Supplies
    Last Post: 02-25-2005, 07:31 AM
