Results 1 to 5 of 5
Thread: Mini-ITX Vehicle PC Case w/ built in 120w power supply question
    Nov 2005
    i have the SP13k, a 100gig laptop hdd, 512 of RAM, a wireless NIC and a bunch of USB devices all connected to my 120w vehicle psu that came with the Mini-ITX Vehicle PC Case w/ built in 120w power supply. Obviously, i run less than 120w. I am using a 400w atx psu as a bench tester untill i get my car (wednesday, march 22nd.)
    So here is my problem:
    The only way i can start my motherboard is by using a power switch that i took out of an old atx computer (same thing as the start-up and shut-down power button that you can buy off the mp3car.com store. If i connect the power switch wire from the PSU it will give me the 2 blinks of green, indicating a boot-up failure, regardless of which way the pins are connected to pins 6 and 8 on the f-panel. If the case is together, the pins for selecting voltage is showing, as there is a slot to change the jumpers.
    What i basically need to know is where is pin 1 when it is in the case? I have tried just about every jumper configuration there is, and i still receive this 2 blink indication when i connect the acc-on wire to the +12v.
    now, does it absolutely need to be connected to a car battery to even use this feature of the psu? do i need to connect some type of fuse to bench test it? anybody have this problem?
    via epia sp13000 mobo
    512mb ddr ultra slim ram
    100 gig hdd
    mp3car in-dash TS
    much more to come!
    Maximum Bitrate srcstc's Avatar
    Dec 2003
    New Jersey
    I have the same case and what I did when I had it out of the car is connect the yellow and black wires to my power supply, wait for the blinking light, then connect the Acc. wire to the yellow wires.
    -Rich
    Nov 2005
    yeh thats what ive been trying. what is your jumper setup on J1? i was reading the manual yet again, and i guess i need to put one on pin 3 to activate the accessory on as a power switch...
    could you possibly take a picture of your jumpers?
    100 gig hdd
    mp3car in-dash TS
    much more to come!
    Dec 2003
    New Jersey
    Quote Originally Posted by shocker1185
    do you mean JU1?
    Nov 2005
    yes, ju1.
    i figured it out. i needed to jump pin 3 on ju1 to turn on standby on or something liek that, and then on j6(i think), the jumper setting, not the auxilary out, i needed to set a jumper on that and then it booted up fine, yeah.
    100 gig hdd
    mp3car in-dash TS
    much more to come!
  1. ATX power supply question
    By dudah85 in forum Power Supplies
    Last Post: 10-10-2006, 04:49 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 11:28 AM
  3. Pc Mini
    By fungke in forum General Hardware Discussion
    Last Post: 06-02-2005, 04:43 PM
  4. ATX, ITX DC-DC Power Supply
    By Navigator_82 in forum Power Supplies
    Last Post: 03-14-2004, 10:26 AM
  5. power supply question
    By perlmax90 in forum General Hardware Discussion
    Last Post: 12-07-2000, 11:16 PM
