Results 1 to 10 of 13
Thread: Battery saver in Europe?
    May 2001
    Thessaloniki, Greece
    Does anybody know where I can buy this from in EU???
    http://www.koolatron.com/electronics/12vbatsav.html
    It's for saving my battery when I forget the comuter in STR.
    Thanx,
    Dimitris
    Jan 2002
    Medford
    Would it not be better and safer to buy jeffs shutdown controller?
    Jun 2000
    Salt Lake City, UT, USA
    Maybe not, because Dimitris1976 uses Suspend to RAM and never completely shuts his computer down. But he still has to worry about not leaving it that way for too long or the battery will drain too far.
    Have you thought about adding a second battery with an isolator so it only drains the aux. battery?
    1983 BMW 733i
    Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
    Gathering parts for carplayer v2.0!
    Sep 2001
    Jamachine you posted an equally useless reply to my similar post. The idea here is that we don't want to shut our machines down because we don't want to wait for them to boot up. Therefore the solution is in finding a way to keep the PC alive in the car longer, not finding a way to shut it down; that problem has already been solved for months, ie Jeff's shutdown controller.
    May 2001
    Jeff's shut down controller is still usefull in my setup
    (I actually use another circuit
    http://bjblaster.tripod.com/Carputer...bjcarputer.htm
    (scroll down)
    that does the exact same thing) in order to hit the power button after 15mins and put the computer into STR mode.
    I need the battery saver for the reasons Falcon62Travis mentioned.
    I don't see why I should use an extra battery and a battery isolator though... The main battery gives you more than 4 days (maybe more, but that's how much I tried it 'till now) of stand by time in STR without totaly draining the battery (the car started right away). Keep in mind that my car has a battery of only 55Ah!
    What's the point having a second battery (most propably smaller=less stand by time in STR) to let run flat everytime (batteries are destroyed when completely discharged acouple of times) and then having to keep the engine running for more than you actually need the car in order to fully charge it again? Not to mention the extra weight, space in the trunk, cabling and money you need for this.
    So...anybody found this batt saver in Europe?
    Or a schematic to build such a circuit?
    Jun 2000
    Wow. 4 days is a LOT longer that I expected. I plan on using STR in my next setup also.
    I don't know how much damage you're going to do to your battery draining it and charging it all the time but I was thinking of a full size Deep Cycle (Marine) battery as the second.
    But I will agree that a Battery saver is easier and will do the job...
    1983 BMW 733i
    May 2001
    Do you think I could use this circuit:
    http://archives.e-insite.net/archive...2696/20di5.htm
    instead of the koolatron product?
    How many Amps can this MOSFET transistor handle?
    Does it reconnect the battery to the load as soon as the voltage rises?
    Apr 2001
    Portland OR
    The next shudown controller will have an option were you can set the shutdown to wait until the voltage hits a certian point before it calls a shutdown.
    Would this be a good feature?
    Rather than a timer, just wait till the battery is at a certian voltage and then call a shutdown. If it is less than 11 volts for say, 1 minute, then shutdown. That way if you restart your car with the computer on. it doesn't care, but if the battery drops that low long enough, it will shutdown.
    Jeff
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Sep 2001
    That would definitely be the icing on the cake Jeff.
    May 2001
    Jeff,
    that would be a really nice feature. I would prefer it though, if this voltage sencing circuit didn't send a ATX pulse (ATX pulse still with a timer) but instead control the relay that disconnects the battery.
    I want this for my setup for the following reasons:
    1) I don't want my LCD screen to "shine" in my car for so long if I forget the pc on. It's like screaming "steal me!".
    2) I would like to have the ATX pulse at 15mins in order to put the PC in STR and then the battery disconnection when the voltage will drop at 11 volts (after some days).
    By the way.... Jeff,
    could you tell me how am I gonna build a circuit like the one you described? Not the new shut down controller you are planning, just circuit that controls a relay (or a MOSFET) and disconnects the load when the voltage drops at 11volts (with the 1min delay, so that it doesn't disconnect when I crank the engine).
