Opus 120 and MTSVO-SC, wiring questions
I've got the MTSVO-SC motorized in-dash screen, and the Opus 120 powering an EPIA MII-12000 board. I plan to power the screen from the Opus, by way of a molex connector which I'll cut and solder an extension from the trunk to the dashboard. I have some questions regarding the wiring for my particular situation. Here are the wiring pin-outs for the PSU and screen wiring harnesses:
OPUS 120:
pin 1: black, GND
pin 2: black, GND
pin 3: red, ON/OFF or ACC
pin 4: yellow, Battery +
pin 5: yellow, Battery +
pin 6: blue, Remote On/OFF
MTSVO-SC screen:
pin 1: orange, Remote
pin 2: blue, Reverse
pin 3: black, GND
pin 4: red, ACC ON
pin 5: green, Park
pin 6: yellow, +12V
1. For the Opus, do both pins 1 & 2 get grounded to the chassis? Why two separate wires?
2. For the Opus, do both pins 4 & 5 get connected to the battery + terminal? Why two separate wires?
3. For the Opus, pin 3 goes to the ACC terminal in the under-dash powertap?
4. Can pin 6 on the Opus be connected to pin 1 on the MTSVO-SC to give the screen the start signal when the system starts via the Opus? The little pamphlet that came with the Opus shows a diagram with pin 6 being connected to the ON/OFF of an external LCD, so I'm not quite sure if Opus pin 6 goes to MTSVO pin 1 or MTSVO pin 4 or neither.
5. For the MTSVO, pin 2 gets sealed off if I'm not using a reverse cam?
6. For the MTSVO, pin 3 gets grounded to the chassis?
7. For the MTSVO, what does pin 4 get connected to, if anything?
8. For the MTSVO, pin 5 gets grounded to the chassis to enable the screen to operate when the car is in Drive?
9. For the MTSVO, pin 6 gets the extended wire from the Opus' molex connector, so the screen gets regulated power via the Opus?
The ones I'm not quite sure about are points 4 and 7, and/or:
Opus pin 6
MTSVO pin 1
MTSVO pin 4
Can you guys help out, skim through points 1-9 and let me know if they're good or if anything looks wrong?
'01
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
