Results 1 to 6 of 6
Thread: So how do I get the PSU to turn on on ING?
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    today I was doing the final connections and when I turned the key on IGN, nothing happened w/ the PC... is it supposed to turn on by itself or do I have to do any other things? I did connect the psu to the motherboard so that shouldn't be the problem..
    I tested the wires with a DC voltage tester and it did work so there is current and the connection to the PSU is good.. the problem is somewhere from the PSU because I hooked up my Xenarc to the PSU and that did not have any power either so it's the PSU but what about it?
    Emo
    Elsewhere
    What PSU are you using?
    If you're using an AC PSU and inverter, then no, it won't turn on automatically.
    How about the Wiki?
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    sorry, I forgot to tell you that.hahah
    no, I'm using the OPUS 150
    so it should turn on automatically but why is not doing that?
    -Emo
    Raw Wave tj!2k4's Avatar
    Oct 2004
    double-check your wiring here: FAQ: How to Wire an OPUS PSU
    also, the motherboard-switch-connector-wires on the 150 (black & red) seem polarity sensitive, so try changing the positions on one of the ends.
    Emo
    Emo is offline
    Nov 2005
    Orlando, FL
    well damn it worked!!! lol I switched the Power On cable polarity like you said and that seemed to do the job!!!
    Thanks tj!2k4 for the help! (you too DarquePervert)
    -Emo
    Oct 2004
    excellent! you're welcome
  1. Replies: 17
    Last Post: 02-17-2006, 05:59 PM
  2. M1-ATX 90W PSU Usefull Observations
    By James141 in forum Power Supplies
    Last Post: 03-11-2005, 09:25 AM
  3. Power to turn on an automobile relay
    By MatrixPC in forum Power Supplies
    Last Post: 01-30-2005, 08:55 PM
  4. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 12:04 PM
  5. Arise PSU problem!
    By mobileh1 in forum Power Supplies
    Last Post: 06-25-2004, 11:14 PM
