Is the video coming from the PC or DVD player when you notice the noise? My understaning (and config) is that your audio source and amplifier should have a common ground, and that the ground wire should be as short as possible (usually the shortest run is to the chassis and not back to the battery).
I'm not sure about the gauge of the ground wire, but it's usually the same as the positive lead. Regardless, I doubt the gauge of the ground wire would cause noise.
LinkBack URL
About LinkBacks
. I was playing with the audio controls and muted the line in while a
