Results 1 to 10 of 13
Thread: M2-ATX J3 (Ignition) Question
    Nov 2005
    Laguna, Philippines
    Did some searching but didn't get the exact information i needed, then again i the search engine might not understand fully my querry. Guys just one question: Thus the J3 (Ignition) require a constant 12V signal?
    Nov 2005
    Wire the IGN/ACC to a 12v that comes on when your accessories (radio, headunit, lights) come on. The cigaretter lighter circuit may be a good point to tap it from if you do not want to break into your steering column.
    The M2-ATX uses that input to determine when to turn on/off your computer depending on your ABCD jumper settings.
    If you wire that that to a constant always-on 12v, the M2-ATX thinks that your car is always 'on'.
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    The ignition wire harnes is a bunch of wires that run up into your steering column. They can easily be accessed by removing the front dash panel below your steering wheel. An ignition wire will be thicker gauge and show 12v when your key is in the start and run positions. Actually you can use either the black/yellow or black/orange wire in your particular car according to: http://www.directwholesale.net/diagr...p?link=BULLDOG
    ATVMS.com
    Nov 2005
    Laguna, Philippines
    thanks for the reply guys but i'm wondering if it is really needs a contant 12V or a 12V pulse can do? I'm thinking of remote PC power-up/wake-up via wireless and the IGN signal is the only problem.
    Nov 2005
    In the context of your question: constant 12v for the IGN/ACC line
    Nov 2005
    Laguna, Philippines
    Quote Originally Posted by piabu
    thanks a lot pal! then i need to source for electronic switch...
    hmmmmmmmn... Anyways this this thread is done unless someone says
    that a pulse would do.
    Nov 2005
    "a pulse would do"
    momentary to constant output relay. I think there may be a few threads on them here as well.
    Or you can always modify the M2-ATX firmware to handle your scenario if you have a PIC programmer.
    May 2005
    Yeah, I used a SPDT relay connected so one pulse locked it to feed 12v to the M2-ATX. The other contact was energized by the amp turn on. This allowed for a pulse start. Using the 10min offdelay built in to the M2 I now have an automatic system to allow for pulse start but not keep the comp on past ign turnoff. Total cost was about 2 bucks.
    Nov 2005
    Laguna, Philippines
    nice piabu!
    i'll try to look for this part!
    By the way, do you have the firmware code?
    I'll try to hack it if i have spare time!
    Nov 2005
    Laguna, Philippines
    Quote Originally Posted by Simon123
    WOW! a cheap way of possible remote turn on. By the way do you have the schematic diagram of your set-up, specific to the subject? Hope you can share with us... hope you don't mind
  1. ATX power supply question
    By dudah85 in forum Power Supplies
    Last Post: 10-10-2006, 05:49 PM
  2. ATX PSU Hack question
    By kgoode80 in forum Power Supplies
    Last Post: 07-09-2002, 06:18 PM
  3. Keypower DC-DC ATX psu question
    By hasato in forum Power Supplies
    Last Post: 01-12-2002, 01:57 PM
  4. ATX POWER QUESTION ! (URGENT)
    By Mastero in forum Power Supplies
    Last Post: 11-09-2001, 09:35 AM
  5. ATX power supply question
    Last Post: 04-17-2001, 10:32 PM
