Results 1 to 10 of 11
Thread: Fuse question
    Jan 2002
    Venezuela
    Fuse question
    I need help with myMPD-8071 power supply.
    I'm trying to test my power supply just connecting the outputs to the motherboard in the car, using an external fuse.
    With a 7A the fuse fail,
    then I used a 20A and works fine, but, when I turn it on again the 20A fuse fail.
    is this normal???
    What fuse can I use??
    what do you recommend me to do??
    Thank you for your help
    Mario.
    Apr 2001
    Here, There, Everywhere
    Re: Fuse question
    The 20A probably fails due to the computers startup current blowing the fuse...... just try the next levels up 25A,30A, etc, etc.... that should be fine. Any fuse is gonna blow anyway in the case of a short circuit......
    Project - GAME OVER :(
    Jan 2001
    Adelaide, SA, Australia
    Your computer is probably drawing more than 20A on start up. Extra power is used in the inital startup, to spin up the HDD etc, During normal operation though, the computer could be using as little at 4A or less.
    Just try a bigger fuse..if you keep blowing larger fuses, then there may be a problem somewhere.
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    Apr 2001
    Portland OR
    I'll bet something else is the problem. I have a 70 watt power supply with a 10 amp fuse and The inrush current never hurt me. If you are pulling more than 20 amps for any reason on a 70 watt power supply. You have a short.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    Jan 2002
    Venezuela
    Now I use a 30A fuse and works fine.
    Thank you.
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Talking
    Don't use a larger fuse...Use a 10A SLOW BLOW fuse. It will allow much more current to pass during initial startup, but still blow after exceding 10A for several seconds...Much safter than simply uprating things...
    Jan 2001
    Use a 10A SLOW BLOW
    I've never heard of a slow blow fuse.
    Well thats my daily learning now, I'm going back to sleep
    mp3car FAQ - RTFF
    Jan 2002
    Melbourne Australia
    Hey do you reckon it should be ok if i just run my +12v power to my inverter straight off one of the connection's on my distrobution block for my amp's with a 20amp fuse.
    http://austmp3car.tk
    Jan 2000
    Slow blow fuses are designed for large inductive loads like motors. They have a small thermal element inside the blows after reaching a certain temperature....If you look at a regular fuse, and then look at a slow blow, you will see the difference. If you still have fuses in your house (I do) you will probably find that you have a slow-blow on your furnace.
    Jan 2001
    I cant see a problem with that, although i would sugest using a relay, possibly wired up to your amps remote lead, so that your inverter isn't constantly on, like it would be wired stright to the dist. block
    mp3car FAQ - RTFF
