Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Inverter problem
    Low Bitrate girbot's Avatar
    Feb 2006
    Houston, TX
    Inverter problem
    I have a 400watt power inverter that powers up to 3.8 amps. My system is a micro-atx board, a cd drive, a hard drive, 2 sticks of memory, keyboard, and mouse. I hooked up everything in a temp case to test out the system in the car. I made sure all the componets inside the case where all in order, and took it outside to test out my new power inverter.
    Long story short, it wont boot up. I ran a extension cord out there and plug it in and it booted fine, but whenever I plug it into the inverter it wont boot. Is there a electricty thing I don't know about? It says 115V AC 400W 3.8AMPS, so it should work.
    What am I missing?
    You know you're an engineer if you have no life & can prove it mathematically.
    Aug 2004
    Atlanta Ga
    Quote Originally Posted by girbot
    What am I missing?
    Have you testing anything else that runs on a/c from the inverter?
    Feb 2006
    Houston, TX
    I hooked up my laptop to it first to test it and my monitor out, then I thought about my full system and decided to test out the full system.
    The laptop booted fine.
    Elsewhere
    Is your inverter plugged into your cigarette lighter or wired directly to your car battery?
    How about the Wiki?
    Feb 2006
    Houston, TX
    It came with both a cig lighter plug and a direct to battery cables.
    I have it running threw the cig lighter.
    Elsewhere
    Wire it to the battery. It's likely too much resistance on the cigaretette lighter plug.
    How about the Wiki?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Yup...
    TruckinMP3
    Read the FAQ!
    Feb 2006
    Houston, TX
    The length of the cables it gave me are only about 2 feet long. What would be the best and fastest way to extend these?
    Note: they look like jumper cables on one end and termenal connectors on the other.
    Feb 2006
    Houston, TX
    O quick thing to add:
    I have two cig lighter ports one of which dosent work (not sure why, the other works). Can I cut the line to the not working one and rigged it to the inverter?
    Variable Bitrate numbers's Avatar
    May 2005
    Does the inverter have a low voltage or protection alarm/led? The first thing I'd try is breaking off the ground prong from the power cable you have between the inverter and computer, though from the information you've given I can't guarantee that as the definate solution.
  1. Problem with Monster Inverter.
    By pirate_king00 in forum Power Supplies
    Last Post: 03-07-2005, 11:20 PM
  2. Setting up a swtich to turn off inverter when computer turns off
    By hd54321 in forum General Hardware Discussion
    Last Post: 11-29-2004, 03:36 PM
  3. HELP! Inverter or PSU problem
    By sygad in forum Power Supplies
    Last Post: 07-06-2004, 09:03 AM
  4. FS:HYPERION Simplicity Series standalone Controller and inverter
    By kickercivic1 in forum Classified Archive
    Last Post: 06-25-2003, 10:01 AM
  5. another inverter problem
    By dizzzyduck in forum General Hardware Discussion
    Last Post: 07-18-2000, 10:55 AM
